NOTICE
for those of you that are updating the SD cards to the latest image files
all of the settings are stored on the SD card. this means that when you re-image the card, you are going to lose any settings that you previously set and saved
when you power up the clock again, you will need to hold in button 3 while powering up the clock. continue to hold down button 3 until the various display types start to cycle. press button 4 after display type 'C' appears to lock in the display type (this is for the HUB75 [rgb] panels)
NOTE: button 1 is the one closest to the SD card
after that, the list below are the setting changes that I made to the initial SD card images sent with the clocks
settings that you may want to re-address after re-imaging the SD card
ANIMATIONS - ENABLE ALL (scroll to this sub option and SAVE)
STATUS LED - change this to 'disabled' (this eliminates that blinking LED on the run-dmd pc board
CONTENT FILTER - change this to 'enable all'
DMD CONTRAST - change this to 'enhanced'
TOOLS - BUTTONS - change this to 'reversed'
