Hi all-
So I just finished a couple month restoration of a 1977 Gottlieb Super spin and have finally moved it into the house and just started playing it. I *think* that the game is playing 100% perfect in terms of rule set, function, etc but I have a question about one part... the roto target... can you tell me if what I describe seems to be how the game is supposed to work...
Look at the center roto target arrow at the top center left side of the play field. Starting at the top the text reads...
"Scores 10X Target Value... then the white insert is lettered "HIT" and the there is a large "&" on the lettering in the arrow and finally a red insert lettered "WHEN LIT" and more lettering on the arrow "STAR TARGET SCORES SPECIAL"
Here is what happens during game play.
If you hit the left or right roto targets (under the metal enclosure you cannot see them) they score the correct value 100-500 and the white insert with the "Hit" lettering lights up fairly briefly - say a second or something, like its indicating that you scored that.
If you hit the center roto target value the white insert with "HIT" lights (just like the sides) but you score 10X the value, so 1000-5000 (unsure what the star gives never did quite hit that yet) and then the white insert goes dark again (like 1 second its lit up).
So, I am guessing this is playing correctly, you ALWAYS score 10x on the center roto target and the white inserts with the "HIT" lettering are simply indicators that briefly light to let you know your hit that target (I guess this is nice as you might not know if your ball hit left right or center). I had initially read that to mean that when the white "HIT" insert lit up you would then score 10x... but that does not seem to be how the game works in that those "HIT" inserts only ever light up after you have hit the target and only for a second or so... thus... I think my game is playing correctly.
Do you agree?
I am also uncertain exactly what triggers the red insert to light up "WHEN LIT" to enable the "Score Target scores SPECIAL".... but it does work and seems to light up only after you have the bonus count up over 10,000 and perhaps something else happens but its not clear exactly what the rule set is to get that one to light. Never have hit the star with that lit up... but very curious what "SPECIAL" is... I bet its good!!
Any comments/experience/intrepretations.. .any knowledge of what the "Special" score is?
Here is the play field in its entirety... to help with rule figuring out. Any resource with rules for this game I don't see any on line anywhere. Manual is not so clear to me but Maybe i need to re-read it again.
Playfield is LED GI from Cointaker, "retro" if your curious... bright white color.
Crappy cell phone pic but gives you the idea anyhow.
