Hey guys. Just bought an STTNG pinball machine and has been working out fine, but noticed that triggering the top LBANK switch would also trigger the under borg start mission switch, and confirmed it by manually triggering the switch in switch test.
The second I put the playfield back together and put the glass back on and tried to play again, the ball return kept throwing balls back into the launcher, as if something was stuck (ie, 5 balls in the launcher, all getting stuck, and the machine was still trying to kick more balls out). I go back to switch test and now I see that switch 37 (under right gun switch 1) is continually triggering without anything touching it.
Help!! I don't know what I've done to ruin the machine!
