(Topic ID: 131324)
Rudys Jaw closes but does'nt open any suggestions??
By Charliew65
8 years ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 8 years ago by SuS
#1 8 years ago
I have my Funhouse almost 100% working only thing left is aligning the left plunger (wich is a pita) and Rudys jaw closes but doesnt open. I just replaced the up/down driver board which I thought would do it but no dice. any suggestions? Thanks in advance.
#2 8 years ago
Are you using repro gears? I had trouble with ones I purchased and just ended up swapping the old original ones back in because of problems with his jaw catching open.
#3 8 years ago
Check your gears. Might be missing a few teeth.
#4 8 years ago
I do have new gears because the old ones were toast completely unusuable...I did a playfield swap and a buddy had it working perfectly but I had to drive it home on a trailer about 200 miles and once it was home thats when his mouth stopped working
#6 8 years ago
probabally so but he is home safe now and has nothing to worry about!
#7 8 years ago
where are all the tech people at?
#8 8 years ago
Be sure to test the motor also. I had the same problem and the issue was a broken winding in the motor. Rudy's jaw would work in one direction, but not the other.
What I found in test (with the motor free of the gears) was that, when current was applied, the motor would sometime start and sometimes not, depending on the position of the rotor. Not all armatures were conducting so the motor would only start up with the armatures on the rotor in a certain position. Once rotation started, momentum allowed the motor to keep spinning. However, if the rotor wasn't in the right position, rotation wouldn't start at all.
When the motor is in the game, the rotor is locked in gear to the jaw, so the rotor is always in one position when the jaw is fully open, and in one position when the jaw is fully closed. In my situation, the motor could start if Rudy's jaw was open, but it couldn't start if his jaw was closed, due to the broken winding.
I replaced the motor, and it fixed the issue. The replacement motor is ridiculously expensive from online pinball shops. I bought one from Radio Shack for under $5, and swapped the gear wheel from the old to the new motor, which was a total pain. Radio Shack part number is 2730256.
$ 59.99
$ 225.00
Professor Pinball
$ 170.00
Displays
Digipinball Shop
$ 40.00
$ 1,059.00
5,500 (OBO)
Haledon, NJ
13,000 (Firm)
Phoenix, AZ
$ 15.95
$ 45.99
Lee's Parts
Bethel Park, PA
$ 22.50
8,000 (Firm)
Reno, NV
$ 25.99
Lee's Parts
$ 25.99
Lee's Parts
$ 9.95
$ 29.95
$ 69.99
$ 17.95
$ 399.00
$ 27.95
$ 26.99
Lee's Parts
$ 14.95
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/rudys-jaw-closes-but-doesnt-open-any-suggestions and we tried optimising it for printing. Some page elements may have been deliberately hidden.
