(Topic ID: 47903)
Read this before you LED your Pin! Rudy doesn't say ouch when you hit him! Resol
By pinrock
11 years ago
  • 24 posts
  • 8 Pinsiders participating
  • Latest reply 10 years ago by pinrock
#1 11 years ago
Hi, on my Funhouse pinball, Rudy does not say ouch when you hit him. I went into switch test mode and the optos in front of Rudy's mouth seem to be working when I put my finger between them or roll the ball through them they register. But during a game, he doesn't say ouch! He used to, this just recently stopped working.
Anybody have any ideas how to fix? Do I maybe have a bad circuit board? Any help is appreciated.
Thanks,
Jeff
Post edited by pinrock : New info
#2 11 years ago
Try reseating the sound rom and the ribbon cables on sound board? If that doesn't help you might have a problem with the sound rom or board.
#3 11 years ago
Even though all other speech works, (the ouch is the only thing that Rudy doesn't say) you think it might be the sound board? I will do as you say and see if it works. Thanks!
#4 11 years ago
Does he give the ouch expression on his face?
#5 11 years ago
no, he does not, react at all...it is like the opto doesn't recognize it's being triggered. If it wasn't for the fact that it worked in the switch test...hmmm...I'm wondering if I have some type of communications problem from the small opto board under the playfield to somewhere else...the superdog opto's work and register, and they are connected to the same small board under the playfield...strange...
#6 11 years ago
Probably not sound board then. Did you also try triggering the opto manually with finger and ball while in normal play mode?
#7 11 years ago
Super dog has optos.? I though they were just bank of targets.
#8 11 years ago
Quoted from fusion301:
The optos I was speaking of for Superdog are on the left ramp at the top, right below the sign that says "Lite Super dog bonus timer on stairs". They are only accessible from the left plunger. I think Rudy says something like " I'm not hungry" when you trigger them.
#9 11 years ago
Quoted from jackd104:
Yes, with the glass off I start a game and use my finger to try to trigger the optos, but to no avail. So the switch test records the optos as working, but must not account for the connection to the electronics that prompt Rudy to say "ouch" and the corresponding motion of his mouth.
Still looking for some help if anyone has any ideas...
#10 11 years ago
Does it still score points during game play when you hit the mouth opto switch?
#11 11 years ago
Stupid question, but is Rudy disabled by accident in the settings maybe?
#12 11 years ago
Quoted from dmacy:
I think that opto would still work, regardless, as it has nothing to do with the operation of Rudy, but good idea.
Check the switch matrix row and column for this opto. There may be another switch that is shorting in and out, and causing issues. Check all the other switches in the same column and row.
Are there any other issues with play? That seems odd, as what you described should at least give inconsistent results, indicating intermittency and a switch or connection issue.
#13 11 years ago
Thats why I asked if it was still scoring the hit - that will help tell you the opto is working during game play.
#14 11 years ago
no scoring, when I trigger the opto's with my finger...
#15 11 years ago
Quoted from dmacy:
Rudy, seems to work fine in every other way except for saying "ouch" when you hit him in the mouth...
#16 11 years ago
Quoted from Atomicboy:
Now that you mention it, every so often rarely, he does say "ouch", which leads me to believe, bad connection of some sort...failing wire, bad connector, etc. I am going to get the multimeter out and at least test continuity.
The strange thing about this is that in test mode, the opto switch is working (triggered when I pass my finger or ball thru the beam)
#17 11 years ago
Quoted from pinrock:
Sorry Atomicboy, I just realized I said what you said like it was my idea... I'll do some testing and repost what I find!
#18 11 years ago
I know everyone is tired of hearing my "connectors,connectors,connectors." Follow the wires back and you may find a connector for just that set of wires. Not sure why they are there other than to make ease of removing the play field for service. Just a suggestion.
#19 11 years ago
OK, I figured it out with all your help. It happened was while installing LEDs
in the game I turned one of the Light fixtures so it was touching another switch in the matrix, I guess causing a short. Once I rectified that Rudy was fixed! It didn't show up in any of the tests, nor did the system indicate any type of error. Morale of the story, be careful when installing your LEDs!
#20 11 years ago
glad to hear ya got it fixed. Hitting Rudy's mouth is required to light the mirror, so it would be impossible to complete the awards without it.
#21 10 years ago
Light the mirror with the inlane.
#22 10 years ago
I think this is a common problem with people installing LEDs. I see a lot of posts that read. "my xxx wont work after installing LEDs!" things are mounted very close together under there. Its very easy for a tab on a lamp socket to swing and touch something else. I was very careful after putting my EATPM back together to make sure nothing was touching. I checked everything under there about four or five times before i powered it on. I made adjustments here and there if i felt something might shift or a lamp socket might swing and potentially touch something else.
#23 10 years ago
Yes, and pinball machines tend to act very strangely when there is a short. When something doesn't work I found it is very easy to fall into the trap of over reacting! I was checking connections between the opto board and the optos, the opto board and the power and CPU boards, checking for continuity, etc. I thought about just buying a new opto board, even cutting wires to isolate the problem! And all the while I was focusing my attention in the wrong place. (To exacerbate the problem, by coincidence, i had some other unrelated problems going on with the machine, some related to the problem and some not..and it started to overwhelm me) Luckily I've been doing this a long time and have learned to ask for ideas, as I did here, and to stop and think!
Whenever I think about taking some drastic action, I walk away from it a while and think. Think about all the facts. After all, in this case it worked before in the recent past. I had just done a bunch of fiddling around with the machine (in other words, making a lot of changes at once) and didn't connect the outage with the installation of the LEDs.
In the end I got out the manual and checked the schematics with relation to the opto that was failing. I then opened the machine and started tracing every wire in the same matrix. It was relatively easy, took a while, but I did it methodically and calmly, not knowing what I would find. That's when I saw the light metal tab touching the metal part of a diode on a switch. I simply turned the fixture so it wasn't touching, and everything went back to normal!
I share this with you all in the hopes it may help you in the future. Good luck and keep flipping!
#24 10 years ago
Ouch!
$ 225.00
Professor Pinball
$ 54.99
$ 9.95
$ 45.99
Lee's Parts
13,000 (Firm)
Phoenix, AZ
$ 170.00
Displays
Digipinball Shop
5,500 (OBO)
Haledon, NJ
$ 25.99
Lee's Parts
$ 199.95
PinSound
$ 59.99
8,000 (Firm)
Reno, NV
Bethel Park, PA
$ 69.99
$ 1,059.00
$ 25.99
Lee's Parts
$ 29.95
$ 399.00
$ 17.95
$ 22.50
$ 15.95
$ 27.95
$ 14.95
$ 26.99
Lee's Parts
This page was printed from https://pinside.com/pinball/forum/topic/rudy-doesnt-say-ouch-when-you-hit-himhelp and we tried optimising it for printing. Some page elements may have been deliberately hidden.
