Hi all!
Got a question on my RS (and a long story about it as well!).
We bought the machine about three weeks ago from a private owner in Maryland. Also picked up a Gilligan's Island from the same guy. (We later found that our Gilligan's Island, interestingly enough, was exported to Germany and then brought back to the US!) Anyway, it turns out that the guy we bought it from had no expertise in troubleshooting problems whatsoever (in fact, I don't think he ever even removed the playfield glass from either machine).
So, when we got RS home, we discovered that the flashers and shaker motor were not working. Long story short, we discovered that the Blasting Zone flashers were causing a short (the two wires were touching).
When we fixed the short, we found out that the Blasting Zone flashers now stay lit solid anytime there is any power whatsoever to the game. The other flashers and the shaker motor, however, all work perfectly. From what I can tell, it seems that the Blasting Zone flasher above the playfield (with a red cover over it) and the flasher under the playfield under the Blasting Zone sign both flash by the same sequence (i.e. both flash at the same time). Any explanation or ways to narrow down the reason they're always staying on solid?
Cheers,
Derek
