Quoted from HowardR:There's one more switch to test: on the Reset relay (D) on the sequence bank, with Blue+Red and Black-Red wires.
That did stop it. So, I manually tripped that switch because when the bank resets it is supposed to be closed, right? As it currently stands, the game is turned on, the motor is off, the coin lights are on and it seems ready to press the start button on the coin door. But when I do - nothing. Isn't it supposed to start the S relay as the first step in the sequence? I tried cleaning the contact for the door button and made sure the switch connects.
I went ahead and tripped the S relay. When I did this the lights came on, it took a credit... but the score motor gets stuck going around and around. Now, if I turn the game on again we are back to the original problem... score motor running because the bank of switches reset and now the D relay is closed.
Does this mean I have 2 issues? 1) that the start button on the door is not communicating to the S relay, and 2) some other switch is not closing/opening finish the start up sequence fully?
Thanks for the help.
