Ok this pin is driving me nuts. Start game button does not start a game. Start relay does not energize the AX relay. Works manually when I engage both coils and when I jump the start coil to the AX. Have checked continuity along the path everything (as far as I can tell) seems fine. Can't seem to find the problem.
Also player 4 changes to next ball after player 3 drops the ball in play. Also kick out coil to put the ball into the shooter trough does not fire.
