Currently trying to trouble shoot my row of switches that are out on my whitewater. (18,28,38,48,58,68,78,88) WHT -GRY
I have tested continuity from the board to each switch affected and it showed continuity there on my multimeter.
Did the jumper test and when I connect the affected pin on J209 to any pin on J207 nothing happened. I tested all other pins on J209 with J207 and all appropriate switches fired.
Next I tested continuity from the affected pin on J209 to U19. My multimeter didn't make a sound but the multimeter went from the reading of 1 to 1944. Does this mean there is a solid connection there or is this my problem?
Also I'm being told the next step is to purchase a Logic probe. Not sure how complicated the next step in troubleshooting is. Am I better off just buying a new rottendog WPC98 MPU?
Any advice is appreciated.
Thanks,
Pete
