Quoted from VolunteerPin:I played this AFM yesterday and spoke with the owner.
The pin actually plays better than I remember the first time around and overall it is in pretty decent shape except for some very major wear around the scoop. (It makes me wonder how wide a field of damage a Cliffy will cover.) The batteries in there do show some corrosion but luckily I did not see any on the board.
Major scoop wear on AFM is common. If it's blown out too far, you need a new PF or a complete restoration as putting a Cliffy over a big hole will just get the Cliffy mangled pretty quick with balls hitting it.
People here are advising you all over the place on price. I use a much simpler method.
Figure out what you consider to be the top price for this title if it has a new PF, new cab art, new plastics, fully tricked out (might as well include a Color DMD). Once you settle on what *that* AFM should cost, start working your way backwards on cost to figure out what it would take to get her AFM up to that point. If that puts you at $2,000, then so be it. *TELL* her that same reasoning. Every person I've ever talked price on a pin with, once they see how much it costs to get their pin up to the top price range, understands that their pin is NOT worth as much as a perfect, CQ version.
After explaining it to her, feel free to offer *more* than the baseline and explain that you're offering that extra to her as you would really like to get this title and it's worth that much more than the going rate to you.
This seems like a very fair approach to me and will also help you gauge if you're going to end up way upside down on a title after restoring it.
Oh and since you said "major scoop wear" on an AFM, I have to add this nasty pic. badafmscoop.jpg
