Hello, I am making progress on bringing a Demo Man back to life. I put a new RottenDog WPC PDB in it but am having a GI issue.
The two strings of GI lights on only the 6 pin (Violet) and 11 pin (White/Violet) of J120 & J121 do not light up.
-I traced continuity from the plugs through the entire circuit. No issues.
-I crimped just these two wires in each plug into a molex connector just to see if there was corrosion in the plugs, no difference.
-All fuses are good, checked both in and out of board.
-Swapping the plugs' location did not change anything.
-If I offset the connectors by one pin, so pin 5 and 10, the strings come on.
Is this a board issues? It is brand new, but all of my checking is telling me it is a board issue.
I see in the WPC schematics that J115 feeds this circuit, so I still need to check that to make sure that plug is fine, so I guess that could be it as well?
If I am putting LED's in, would there be any problems with wiring these to other GI lines so they light? One is a string in the backbox (J120) and the other is the left sling/return lanes (J121). I could tap into the other strings in the backbox for J120 and the right sling/return for J121.
Thanks in advance for any insight! I will post if it ends up being J115.
-Drew
