(Topic ID: 195895)
Rottendog Whitestar driver issue
By gregh
6 years ago
  • 14 posts
  • 9 Pinsiders participating
  • Latest reply 4 years ago by barakandl
#1 6 years ago
I'm working on a high roller casino for someone and it's doing something very strange.
The owner put a rottendog driver in it, and now unexpectedly during a game, all of the coils will shut down. I've never seen this before. The game is still active; IE it's constantly ball searching, the switches still function, game is in play etc. If I power cycle it, everything is fine again until the next time it happens. I don't have the old driver board to swap in and test, so I'm looking for a little guidance. I have an email in to rotten dog about it, but I haven't heard anything back yet.
Any thoughts are much appreciated!
#2 6 years ago
I have a Ripley's that is doing the same thing. The coil power flutters a a bit and then it goes dead. It also has a Rottendog driver board and I have been trying to track down the problems for weeks.
#3 6 years ago
Mine does the flutter as well. I found one thread where someone was having that issue with the RD board, they put in an original and the problem went away. I would hate to have to do that.
#4 6 years ago
Get a hold of Rottendog themselves. I had the same issue, coils would die, but game stayed in play. Sent the board back to Rottendog, they confirmed it was a board issue and sent me another one.
#5 6 years ago
Quoted from blowback1976:
Waiting on a replay. I might try a phone call tomorrow.
#6 6 years ago
Quoted from Jodester:
#7 6 years ago
Ok follow up and end to this thread. I talked to Rd on the phone today. They advised me to short pins 3 and 4 on U210. I soldered a resistor lead to each leg on the chip.
Well that fixed it. Played all night and everything worked flawlessly. Not sure if this has been fixed or not on the most recent boards (this one was purchased recently from big daddy, so it may have been older stock) but that's what worked for me. Also, pin 1 is the top right of the chip for reference.
Hopefully this will help someone else having the same issue.
Cheers
#8 6 years ago
It appears pin 3 (voltage tolerance) pin was left floating on their design.
That input is supposed to be tied high (reset at 4.5V or 10% VCC tolerance) or tied low (reset at 4.75V or 5% VCC tolerance) and should never be left floating.
Adding the jumper from pins 3 to 4 selects the 5% tolerance. If the 5V line dips below 4.75V then your board will reset (which is what it is supposed to do with that setting).
#9 6 years ago
Quoted from G-P-E:
Great explanation. It seems years later Rottendog is still not as reliable as they claim to be.
#10 6 years ago
Quoted from G-P-E:
Yes thanks much for the explanation. I have to say, they were really quick at calling me back to give me a fix for the issue. No love lost here.
7 months later
#11 6 years ago
dumb question but does anyone know how to identify the boards needing this mod from the newer ones?
1 year later
#12 4 years ago
This is not just Rottendog's board. Sega/Stern White Star games all had pin 3 floating as per Service Bulletin SB112. See my post here on the theory.
https://pinside.com/pinball/forum/topic/tech-tip-fixing-intermittent-issues-white-star-sega-stern-games
Rottendog tells me that they now have pin 4 tied to Gnd (5% or 4.75 trip).
As before if that is too sensitive then lift pin 3 and tie it to pin 8 (10% or 4.5VDC)
John :-#)#
flippers.com
6 months later
#13 4 years ago
I am having this issue on Stern SAM System, does anyone know what could cause that? Avengers LE
#14 4 years ago
Quoted from Y3AG3R:
Stern SAM is a different design but the same DS1232 is being used with the tolerance set at 5% per schematic from a spiderman manual I am looking at.
I wouldn't cut anything off the dallas reset chip yet. Check that the mounting screws are connected well on the voltage regulator on the big heat sink. Some games they used a 2nd black heat sink on top of the first one that does not conduct well from the case of the voltage regulator through the screw to the PCB. When the screw loosens up slightly it can go open circuit when the game vibrates. What is the 5v DC reading at with a DMM?
Check this old post for more info.
https://groups.google.com/forum/?fromgroups#!searchin/rec.games.pinball/regulator$20screw$20stern%7Csort:date/rec.games.pinball/M4RjhOyNumc/pPLJrqMmkUoJ
Here is the original sega service bulletin if anyone is interested.
http://arcarc.xmission.com/Pinball/Stern%20Service%20Bulletins/sb/sb112.pdf
$ 12.95
$ 100.00
PinSound
$ 17.00
Nordic Pinball Supply
$ 76.00
Lighting - Backbox
Arcade Upkeep
$ 45.95
$ 12.00
Tools
Nezzy's Pinball Prints
$ 18.95
