Having trouble with a High Speed - was working great after the WDP3211A install. Late Friday night, thing shut down and would not come back up. Bad burning smell. Visual inspection only yielded potential burn on R7 on the display driver board.
Prior to the WDP3211A install, had display #2 burn out on me.
Replaced display driver board with known good unit, replaced display #2 also. Prior to WDP3211A, the 100V section on the original power supply took heavy heat damage and burned the 100V diode and the 202 transistor, so I purchased a WDP3211A - thinking I didn't want to run through replacing parts again.... but I may just do that anyhow.
1. PSU replaced.
2. Display driver board replaced.
3. Display #2 replaced.
4. No other displays witnessed faulty.
Now, disconnecting everything from the Rottendog WDP3211A but the two 3x connectors, CN1x12 and CN3x9, and powering on, I'm trying to get DC voltages across the fuses -F4, 5, 6, 7 - but I get nothing. The fuses pass continuity test.
I see the test points on the board, but not sure what ground I should be using, as connecting to the test points and CN6x15's ground pins (1, 11-15) yield no voltage.
I've verified that the system is getting AC as the aux connector inside the box works and is supplying 115VAC.
Haven't tested the transformer, not sure where to start, but have seen a few on here from posters wiser than I.
Thoughts?
