I recently had an issue with my IJ where the right ramp flashers were all locked on. Thanks to some digging and some guidance from Pinside, it was isolated to a single faulty transistor on my Rottendog driver board (WDB089). I replaced it, and that seemed to solve the problem of the flashers staying on, but now the flashers in question are…dimmer? Only the ones associated with the right ramp, though – all other flashers are just as bright as ever. You can see it in this test mode video comparing the normal bright left ramp flashers to the now dimmer right ramp:
The Rottendog board is laid out a bit different than the original board was. For one it has far fewer transistors than listed in the original manual, and instead has a whole bunch of what appears to be surface mount resistors on the backside of the board behind the transistors, making transistor replacement a little trickier. I wish I had taken a picture, but everything is already hooked back up.
Anyone with a Rottendog power board have any insight on this? Problem with the new transistor? Improper placement of the resistor on the backside? Something else I’m missing? I’m still an amateur when it comes to electronic components, so any simple explanation or thoughts on a possible solution is appreciated!
