I just purchased a Laser Cue machine with a new rottendog board and the game is playing a little funny. I read in a couple other posts that the dip switch setting can cause confusion and I am wondering if mine might be reversed.
The DS3 dip switch box has the tabs that rotate instead of slide. When the tabs are sticking out on the bottom (which is labeled open), does that mean the tab is set to 0 or 1?
If I try reversing the last six switches to check and see if they are reversed, could this cause a bigger issue?
By playing funny here is what I mean - I am testing the targets manually with the glass off. I know the targets must be hit in order in this game. 1,2 and 3 all register fine. When I press the 4 target it drops but the 4 light still blinks. If I complete P-O-O-L above then the 4 registers and it moves to five. I have the same issue with the 6 ball and also with one of the L targets for B-A-L-L.
Thanks for any help you can provide!
Scott
