Hi , i have the same problem . I think i put one wire in the wrong spot and now i have scoring issue . Can you post a better picture of the wiring so I can see where I went wrong . Nobody answered my post either . Maybe together we can figure it out . Tks
Quoted from steamfitter:Hi , i have the same problem . I think i put one wire in the wrong spot and now i have scoring issue . Can you post a better picture of the wiring so I can see where I went wrong . Nobody answered my post either . Maybe together we can figure it out . Tks
I will get a better picture and post tomorrow.
Hey there ~ I'm not sure if this will help, but here are a few pictures of the roto target on my Close Encounters. It's an EM though, so it might not be applicable. The wiring looks different than yours. I just picked it up around the holidays, and I don't know if it works properly. However, all of the wiring looks intact.
I did just order the schematics too. Let me know if I can get other pictures or help out in some way.
Thanks ~ Matt
Just fixed mine , pretty simple ( after checking pics ) . Two wires per contact , one wire to the two spring loaded contact the other wire to the two sleeves of the spring loaded contact . And one contact goes to ground , one wire from sleeve one wire from spring loaded contact . So the one that is missing a wire either on sleeve or spring that's where it goes . Just hope I didn't make this more confusing .
Quoted from Pin-one:Don't think the triangle thing matters.
You might wear out that bakelite without it, then you'd need to find a whole new disc. Pretty common part (the triangle) I'd try and get one just to save the wear.
This page was printed from https://pinside.com/pinball/forum/topic/roto-target-wiring-photo and we tried optimising it for printing. Some page elements may have been deliberately hidden.
