(Topic ID: 264741)
Rotisserie without C-Clamps
By Pin-Pilot
  • 24 posts
  • 9 Pinsiders participating
  • Latest reply 4 years ago by Pin-Pilot
  • Topic is favorited by 13 Pinsiders
    11
    #1 4 years ago
    With all this time on my hands I have been cutting, welding and designing.
    The main drive behind this rotisserie innovation is I despise using C-Clamps on a rotisserie to hold the playfield. They get in the way of the rotisserie frame if they are not flush, they snag on everything, and they will leave marks on your new playfield if they are not protected with some type of pad. The footprint on a C-clamp is just too small. Plus now my C-clamps are all used up on my rotisserie and can't use the for something else. I also wanted something integrated and dedicated to my rotisserie.
    So I decided to make a better clamp system. I think I hit the nail on the head here. This is just the one side. I may do one with one longer piece for the back of the playfield. The only problem I can see with a longer piece is it will possibly interfere with mechanics on the playfield. That is why I made these fairly small.
    I also will be adding some type of material to the clamp so it will not scratch the playfield once I paint or powder coat them.
    Any thoughts/input on these? Actually I am a bit surprised with the talent on this forum that something like this has not been done before. Or maybe it has I have just not seen it.
    All these parts are from my local Ace Hardware. HD also has all this stuff as well.
    IMG_5613 (resized).JPGIMG_5613 (resized).JPGIMG_5614 (resized).JPGIMG_5614 (resized).JPGIMG_5615 (resized).JPGIMG_5615 (resized).JPGIMG_5616 (resized).JPGIMG_5616 (resized).JPGIMG_5617 (resized).JPGIMG_5617 (resized).JPGIMG_5618 (resized).JPGIMG_5618 (resized).JPG
    #2 4 years ago
    that's excellent
    #3 4 years ago
    Nice! the C clamps are one of the big reasons I don't like rotisseries
    #5 4 years ago
    Glue some felt to the angle and clamps and this will be perfect!
    #6 4 years ago
    Quoted from GRUMPY:
    Exactly, I need to paint it or Powder coat it first. Chrome would sure look nice.
    #7 4 years ago
    Quoted from Pin-Pilot:
    Yes but not needed, just a quick coat black paint. Most of it will be covered with felt anyway. Money saved can be used to buy leds.
    #8 4 years ago
    Quoted from GRUMPY:
    Yea, wise words. I think Red paint might do the trick.
    #9 4 years ago
    Quoted from zacaj:
    I cannot stand the C-Clamps either.
    #10 4 years ago
    Genius! Will you be selling sets, Pin-Pilot ?
    #11 4 years ago
    Quoted from xeneize:
    Genius! Will you be selling sets, pin-pilot ?
    No plans on making and selling sets. If I had the ability to mass produce them I would. I just do not have the needed equipment to produce large amounts of these.
    #12 4 years ago
    Got the parts I was waiting for today and the new Rotisserie is in place.
    You can see my old Rotisserie (painted Red, that uses C-Clamps, yuck) I made last year in preparation for my High Speed Playfield swap. It was my first off rotisserie. The new design is essentially the same with a couple small revisions. Off to the paint shop now.
    The new clamp system is in essence similar to my old round clamp system however this new clamp is 100 times better, stronger and much cleaner. Along with no need for C-Clamps to hold the playfield I am quite happy about!
    In full Disclosure. The new friction green rotation clamp system is borrowed from @wrd1972. He is selling a quality Rotisserie you can see here.
    https://pinside.com/pinball/forum/topic/gauging-interest-in-all-metal-pf-rotisseries-for-18000-shipped#post-5267046
    New_Old_rot (resized).jpgNew_Old_rot (resized).jpgNew_rot (resized).jpgNew_rot (resized).jpg
    #13 4 years ago
    Great idea! I'm definitely going to add that to my free standing one that's similar to your table top version.
    #14 4 years ago
    Painted, felt added and a couple minor adjustments and it's doing the job.
    Attaching the felt to protect the play field surface
    IMG_5693 (resized).JPGIMG_5693 (resized).JPGIMG_5695 (resized).JPGIMG_5695 (resized).JPGIMG_5694 (resized).JPGIMG_5694 (resized).JPG
    Put in smaller diameter springs for more grip on the playfield surface
    In Action...
    IMG_5697 (resized).JPGIMG_5697 (resized).JPGIMG_5698 (resized).JPGIMG_5698 (resized).JPGIMG_5699 (resized).JPGIMG_5699 (resized).JPG
    #15 4 years ago
    Looks really good!
    #16 4 years ago
    Thanks, Works great.
    It will not fit on the back end of a playfield if there is a back board on the playfield. I need to spend a little time to make a work around for that.
    #17 4 years ago
    yeah let me know if you come up with something, I was thinking a long piece of steel, bent at a 90 that would clamp at the top of the board, and then use the screw down system you have now to tighten it. But how to transition to the "threaded" portion of the mechanism to allow that? ...
    #18 4 years ago
    This is great! A couple questions..
    Did you square off the hole on the rotisserie for thew carriage bolt, or does the spring give enough tension that you don't need it?
    Did you omit the collar/washer in the final design?
    #19 4 years ago
    Quoted from Shredso:
    It is a pain in the butt squaring off for the carriage bolt. I did do it on the original design with the knob on the small clamp side. I did not square off the small clamp yet but will be doing it. the spring did give some tension. The carriage bolt does bite enough to hold it from turning. But the best and cleaner route is to square the hole for sure.
    The collar in the first design was there to elevate the knob making it easier to grasp since it was close to the long angle iron.
    monkfe suggested flipping the bolt putting the knob on the other side unobstructed. When I did that the knob was unobstructed so I did not need the collar. I did put a washer below the Knob though.
    #20 4 years ago
    Also find the smallest diameter spring that will fit the bolt. Gives more space for the playfield to be gripped by the clamp. I used a fairly stiff spring, holds the clamp open much better.
    #21 4 years ago
    I finally got around to putting this together today. I wound up using 5/16 carriage bolts as I drilled it pretty close to the inside edge of the angle iron, but there was just enough room for a spring to fit. Came out pretty good..Just need paint at some point and some felt. Overall it came out great and no more C-clamps!
    #22 4 years ago
    Quoted from monkfe:
    Nice. I really like the functionality. It is so much better than C-Clamps. Post a pic when you get a chance. I'd like to see your work.
    #23 4 years ago
    ah got to paint for glamour shots!...I thought of another way of doing the longer(rear) clamps...just use a really long carriage bolt...replace the one that's there and extend it through the bottom of the rail. Should work...
    #24 4 years ago
    Ok, will be looking for the pics.
    This page was printed from https://pinside.com/pinball/forum/topic/rotisserie-without-c-clamps and we tried optimising it for printing. Some page elements may have been deliberately hidden.
