I have a Williams System 6 pin and I notice that sometimes when the ball goes over a rollover switch it will sometimes register multiple times, at worst sometimes adding three "hits" (easily noticed when the bonus counter rapidly lights up). It doesn't occur on all the rollovers and on the ones it does happen on it doesn't happen all the time. I tried gapping the switches very far and then very close but no dice either way. I also tried burnishing the contacts with a burnisher that's safe on gold contacts but still seems about the same.
My guess is that the switch is bouncing open and closed ever so slightly to register multiple hits on a single rollover of the ball (it seems to occur more often when the ball is fast). If so I'm guessing the switches are just fatigued and need to be replaced. I'm guessing that adjusting them several times didn't help with the fatigue either. Have any of you ran into this before and found any good solutions? Thanks!
