Hmm, this is going to be tricky and made a little harder by the fact your logic probe has no "low" indicator. Your green "level" indicator only tells you when a signal is high. Without the low indicator you have no idea if a signal is floating open circuit/midrange voltage or if it is a logic low (zero volts).
See here: Logic probes typically have Low, Hi, and Pulse indicators.
https://pinside.com/pinball/forum/topic/terrybs-guide-to-logic-probes
BTW, sorry I should have told you from the beginning to set your logic probe to TTL, not CMOS. Some results will probably appear a little different. Essentially what we were looking for above was activity on those signals to the ROM bus to make sure there weren't any open circuits.
Let's go back and try the simple stuff. Install the U1, U2 and U6 ROMs into the replacement board. Maybe the action of removing/installing the ROMs will have swiped the internals of the sockets to give better connection and try it.
If no luck, then remove U7, U8 and U10 - they aren't needed to get past the ROM test.
If no luck, swap the U9 CPU chips between the boards.
If no luck, remove U11 and install the U10 chip you previously removed into the U11 socket (U10 and U11 are the same type of chip). We need U11 populated because it drives the MPU LED and gives us feedback of what's going on.
BTW2, what's the picture in the previous post about?
