Quoted from Txos:The number is different. Looks like someone swapped the board. I’m in way over my head now! I can’t get half the backglass lights on or the WILLIAMS lights! Ugh.
The number that matters is the "-576". If it's something other than that the it came from a different machine. The number will specify the original machine the board was configured for. There may also be a Williams sticker with the game number on it as well as the serial number. The game number should match the dash number of the board part number.
I make replacement interconnect boards. If you don't feel comfortable working on your board I'd be happy to build a board for you that is customized to Rollergames. Of course ... a new board does not necessarily solve any other problem that may not be related to the board.
You could also send the board off to a reputable repair person to change the configuration of the board you have. Personally ... I think that's less than ideal as it will be confusing being labeled from the factory for game A but actually configured with resistors for game B.
