Hi fellow pinheads,
I bought my first pinball machine a few weeks ago ( Rollergames ) and I've been struggling with a few issues.
When we played the first game, I found out that the Knocker (07A), Upper kickback (13), Lock Kickback (14), Ramp Diverter (18) and Outlane kickback (20) weren't working.
I read a few tips on system11 and busted out the DMM. The Outlane kickback (20) was only reading 1.4v at both lugs even in diagnostic mode, so it made sense that it wasn't working properly.
I checked all the fuses on and they all beeped but I found out some of them were way higher in amperage than they should be so I replaced them with what is listed in the manual. Still not working but wasn't surprised. Then I found out there was a hidden fuse below the playfield (2 1/2A) that was blown. I replaced that one and now the Outlane kickback (20) worked but was stuck open. Also, the flippers were super weak. Then I saw that the F7 fuse on the auxiliary board had blown. Replaced it and now the 3 bank target (WAR) doesn't reset, the ball popper doesn't work and all the other problems that I had before stayed too.
Today I was reading the manual and there seems to be an error somewhere regarding the correct fuses to use.
Could it just be my problem all along was the blown fuse and since I replaced the (2-F4 and 2-F7) 7A for a 21/2A and 4A respectively that it doesn't have enough power to work properly?
Thanks for your help!
AuxiliaryPowerDriverBoardPage44 (resized).pngFuseListingPage40 (resized).png
