Quoted from Hotrob:The diagnostics--I turn on the machine and I get one ding. I watch the LED's and the left LED goes solid the center LED blinks very fast and the right LED blinks and goes solid.
That sounds like a fully booting board to me? (per some info previously posted in the internet)
System 11a, 11b, 11c CPU board LED's.
On system 11a, 11b, and 11c CPU boards, there are three LED's about in the middle of the CPU board. For a working game, here are what these three LED's should be doing when the game is turned on and in attract mode:
Left LED (labeled "+5 vdc"): shows that +5 vdc is present. This LED should always be on.
Middle LED (labeled "diagnostics"): should be continually flashing.
Right LED (labeled "blanking"): shows the blanking circuit is working, and should always be on.
So that appears OK. But, looking at the pic you posted, I also remembered this:
I turn my system 11 game on, and the score displays will only show 0's and X's in the middle of them.
Problem: the game thinks you have "slammed" it.
Answer: there is a slam switch inside the coin door, just above the coin door lock. This switch should be normally open. If this switch is shorted or bent closed, you will have this problem. Often people will accidentally bend this switch when putting credits on the game (a good reason to have the game set on free play!). If the switch is not shorted closed, the switch matrix could also be damaged, as the slam switch is part of the switch matrix.
From looking at your pic, I'd be all over this as a possible solution. You've obviously got some segments missing from your displays, but otherwise it appears to be the same symptom.
