Rollergames Pinball - Tech Help
(Topic ID: 231285)
By jpd632
43 days ago
  • 17 posts
  • 6 Pinsiders participating
  • Latest reply 11 days ago by jpd632
#1 43 days ago
Hey,
Never posted on here before but I ran into an issue the other night thats got me a little stuck. I was playign my rollergames pin and after I shot the ball off all of the kickbacks on the machine just stopped working. I've look at a few things but I'm stuck. Any help or ideas would be great. Its in perfect working order before.
#2 43 days ago
Do you have a DMM?
#3 43 days ago
What do you mean by "all of the kickbacks"?
Ron ..
#4 43 days ago
Gizmonic,
Everything that pops the ball. from the launch to the pit to all of the the bumpers. Sorry i should have been more specific.
Thanks.
Grumpy,
I do, I was gonna bust it out after I checked in with pinside. Wanted to see if it was a quick or normal error.
Thanks.
#5 43 days ago
Meter out the fuses, especially F1 and F2A, and try the solenoid and flasher tests.
On Rollergames there's a relay that switches power between the solenoids and the flashers, the "A/C" relay. It's on the bottom of the playfield near the rear. You might have noticed that if you get a jackpot then immediately put a ball in the pit, it won't pop until the flashers are finished.
#6 43 days ago
Ratshack,
I ran the tests last night. The flasher test worked fine but all of the solenoids were out. That A/C relay, would I have to change out the whole relay?
#7 42 days ago
Test all of the fuses first. Remove them one at a time with the game off to test them.
#8 42 days ago
Quoted from jpd632:
Ratshack,
Don't worry about replacing it unless you can prove it's broken, but keep it in mind while you're troubleshooting.
#9 42 days ago
easy peasy..set play field up with a prop rod and check voltage at the coil. If no voltage then check fuse. If still no power check power supply.
If no power is found its not a bad idea to quickly meter out the coils after you turn off the game of course.
If a bad coil is found check the diode first before you change it out. Let me know what you find then we dig deeper.
Cheers!
#10 42 days ago
Quoted from jpd632:
What exactly does and doesn't work? This will pinpoint where your problem is.
#11 41 days ago
First off. Thanks a million to everyone who responded. I've been super busy at work and haven't been able to have the time to check everything yet.
Ratshack and Hawk - I'm going to meter on Saturday when I have the day to work on it.
Grumpy, everything works except anything that pops or launches the ball. None of the bumpers react, all of the drop targets are down and wont reset, the launch and pity aren't working.
Thanks a million guys. this is my second pin and I'm new to this hobby, I'm still learning and I can't tell you how much I appreciate the pinball communities help.
3 weeks later
#12 16 days ago
Update. So Its been a busy last month or so withe the holidays and work, so I haven't been able to look at it and devote time it it until today. Im getting power but none of the relay points are working or resetting ..
I've added a youtube video link.
Any help would be great thanks so much! I'm still new to this and I appreciate any advice/help!!
#13 16 days ago
You need to check for voltage at the coils. You may have a burnt fuse on the aux power supply.
#14 16 days ago
FIXED! Grumpy, if you are at Pintastic Massachusetts in June I owe you a beer! Thanks a MILLION DUDE!!
#15 15 days ago
Playball!!
#16 13 days ago
yup just what I figured. Always check power at the coil first. it will tell the tale.Cheers and glad you got er going. Any more troubles just post back.
#17 11 days ago
Thanks Hawk! I appreciate everyone's advice and support. I've collected comics since I was 7 and I'm 37, I've played guitar since I was 16, Love the NBA and have many other hobbies; No question that Pinheads are by far the most friendly, supportive and helpful hobbyist I've encountered. Thanks fellow pinheads!
$ 29.99
PinSound
$ 22.00
Yorktown Parts and Equip
$ 18.99
$ 7,499.00
Flip N Out Pinball
$ 45.99
Lee's Parts
£ 58.00
Metalhead Pinball
$ 159.99
Gameroom Mods
$ 48.00
Great American Pinball
$ 999.00
