(Topic ID: 310565)
Rollergames multi ball problems
By Jvjm
2 years ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by Shogun00
#1 2 years ago
Help. NY Williams Rollergames multi ball option isn't working correctly. Two balls get locked.. the third is supposed to release them all for multi play. However, the game keeps displaying "2nd Ball Locked" and holds the third ball. After a minute, the game releases only one ball for play and gets stuck on that same player even when the ball goes. Also, when two balls are locked waiting for the third, the last ball won't feed. The game plays fine otherwise if no balls are locked in the multi ball playing chute. Rollergames
#2 2 years ago
Have you tried testing the switches in switch test? I'd get a look at the switch matrix chart in the manual and verify that all the switches are working properly. If you find one or more non working switches, verify that the wiring and diode is hooked up properly. It's possible you'll find a broken off wire or diode leg. I usually give a light tug on the wiring and diode to be sure they're firmly connected.
#3 2 years ago
A problem similar to this has been posted on this forum before. Double check the switch wire colors and location. I am fairly sure the manual has this information listed incorrectly. Use the game diagnostics to figure out what is actually correct. You can determine switch state from test 07 - switch edges.
Note that lock #1 is the LOWER lock as it locks first despite what the manual location shows. Lock #2 is the upper lock as it locks second. There is no switch for the third ball when it locks. The game knows that the three balls are there based on lock #2 and the third ball passing through the second ramp diversion and subsequent switch.
01_switch_locations.jpg01_switch_locations.jpg02_switch_wire_colors.jpg02_switch_wire_colors.jpg
#4 2 years ago
Ran into the same exact problem 2 years ago. I just had to adjust the leaf on the Ball Lock 2 micro-switch to fix the problem.
#5 2 years ago
frunch Thanks for your response. I will definitely check the wiring and diode legs to ensure they're correct and not disconnected. The help and input is very much appreciated.
#6 2 years ago
DumbAss Thank you much. This is a great help with the diagram and all. I do have to perform a switch test like frunch also recommended. I am new at all this, but learning alot from fixing up this old machine. Thanks again.
#7 2 years ago
Shogun00 Thanks much for your feedback. Those are the wires which touch the balls, correct? I started looking at that but didn't want to fiddle around too much in fear of breaking one. I'll have to take a closer look. Much appreciated.
#8 2 years ago
Quoted from Jvjm:
Correct! The wire is welded onto the leaf. I just adjusted the leaf (not the wire), so it could consistently click the little button on the microswitch.
Gweem's Mods
$ 27.00
NO GOUGE PINBALL™
$ 54.99
Springfield, IL
Lafayette, LA
$ 12.00
$ 27.95
$ 18.95
$ 1.00
Pinball Alley
This page was printed from https://pinside.com/pinball/forum/topic/rollergames-multi-ball-problems and we tried optimising it for printing. Some page elements may have been deliberately hidden.
