This has been driving 2 of us crazy here for about a week and we are completely stumped and pretty much out of options. First off all of the coils work fine and it is switching from them to the flash lamp circuit. In test mode Flash Lamps 3, 4, 6, 7 and 9 flash but are so dim they are barely noticeable. If I pull J11 off the interconnect what is supposed to flash works as it should. Same for J12 if it's pulled everything on J11 is good. I've replaced U18, U19 and U20 on the CPU along with their associated resistor arrays with no change. If I pull 1J11 off the CPU and ground each pin in the connector I get a bright normal flash at each wire. Where to go from here??? All of the boards in the game look line new with no burnt, loose pins whatsoever. On a side the interconnect resistor values are different than what the manual shows. There is no Williams number sticker on it to verify if it was for this game Thanks!
PS: If it matters this is an early game #44 with the 15 flash lamp insert.
