My Rollergames started having an issue this morning where the W in "WAR" would not light or make any sound after knocking the target down, A and R would light and the lock would turn on, but not always right away. I had a similar issue with all 3 targets at 1 point and turned out to be a loose molex on the opto board. I figured I would start there so I removed connector and put backfirmly into place(it did not seem loose). Started up and now not only does the letter not light but knocking down all 3 targets does not trigger the lock. I started by cleaning the u opto with a tiny bit of alcohol on a qtip, no help. reading for all 3 letters on the test nodes of the board is the same at 10.1, in switch test mode the W target does not register. all of the switches in the same row/column are functioning fine. also switch does not appear as an error on start up, any and all help and advice appreciated, my wife's favorite machine down, so pressure is on
20230225_154928 (resized).jpgScreenshot_20230225_160648_Gallery (resized).jpgScreenshot_20230225_160810_Gallery (resized).jpg
