I have a Rollergames I've been working on for a while, and while everything else seems to be on the up and up, I've been finding the ball getting stuck towards the middle of the Wall ramp, between where the 2 ramp diverters are. What appears to be happening is that the 2nd diverter comes out a moment too late and smacks the ball into the opposite side of the ramp. Then the ball just hangs out there. I tried adjusting the switch before the 2nd diverter to make it actuate a little sooner, but then the tension becomes greater for that switch/wireform and will sometimes trap the ball as it tries to pass through it. I get the impression this is one of those things I'll just have to keep tweaking until it's just right. Is that the case? Any other Rollergames owners/techs run into this problem? If so, what got it working properly for you?
All help appreciated!
Trevor
