Hi. Just want to thank you, in advance, for taking the time to help me out.
A little background: The ball popper wasn't kicking the ball up into the wire form, the upper flip wasn't returning to its normal position, a few #44 and #555 bulbs were out, the flashers haven't flashed in the last year I've played the game and, in general, it needed some TLC. First, I found the broken wire to the ball popper and soldered it back on. Next was the upper flip. Broken spring. Replaced with new spring. I then went through all the bulbs. Wiped the good ones(had a layer of dust on them) and replaced a few burned out bulbs. Now that I have brightened up the PF and have corrected the mechanical issues, I took a moment to inspect all the wiring and connections. I noticed a 2 1/2 slo-blo under the PF was burnt and when I replaced it, it burned out again. I also ended up with F2A (5 Amp slo-blo) popped.
I pulled the schematics and traced it all out. I decided to remove the coils on this circuit to find which one was the culprit. The outhole kicker, shooter lane feeder and lock diverter share this circuit. First, unplugged the connector associated with those coils to F2A on the aux power supply board. Powered up the pin. Went through boot up. No blown fuse. I unsoldered the brown wires on the outhole kicker and shooter lane feeder coils. Powered up. No blown fuse. Next, I introduce the shooter lane feeder back into the circuit. Powered up. No blown fuse. Last, I introduced the outhole kicker. Powered up and after boot up, noticed that the fuse began to glow. Powered off immediately before it popped. Decided to to remove the lane feeder and lock diverter from the circuit. Powered up and completed boot up. This time the fuse began to glow but very slowly but getting brighter. Immediately powered off. Removed that coil from the circuit and reintroduced the other two coils since they were not blowing the fuse. I took the loose wire to the outhole kicker coil and tapped it to the tab it would normally be soldered on. The coil activated but was stuck in the energized state. I took a glance at the aux PSB and noticed the fuse begin to glow. Removed the wire and the fuse dimmed back to normal.
With this info I looked at two options replace the coil or the transistor that controlled that coil. Started with option A, replace coil. Tested by leaving the brown wire off and tapping it to the new coil, as I had done with the original coil. The new coil gave the same results as the original coil. So, I looked at the schematics according to the drawing, Q33 is the transistor for that coil. Before removing the CPU board, I wanted to see if there wasn't anything else that could be done.
Here are my questions :
1)If replacing that transistor does not fix the issue, what other component(s) should be investigated?
2)Is this issue somehow related to the flashers not working?(I noticed several other transistors also used for “A” and “C” circuits)(This game played for over a year without them)
3)If the game was working with the 2 ½ Amp fuse under the PF blown. What is it used for?
Again, I have some understanding of electrical/mechanical but not an expert. I'm pretty sure it's a “simple” repair but wanted some advice from you guys.
