I've finally decided to take the plunge and try to fix up my battered old R&B cabinet. The back end of this had a new section of MDF fitted a while back but it wasn't as tidy as I would like and there was still some fairly substantial damage that needed patching in.
I've now fully stripped down the cabinet with a view to replacing the back with a new piece of 18mm ply. At the same time I want to make it as true to the original as possible so i'll be looking to cut holes for a new cord cup and reinstating the original rotolock mechanism.
The section that sits directly below the head is also very badly split and ideally needs replacing but I have no clue about how to go about removing it without causing damage to other parts of the cab. I guess what i'm really asking here is a breakdown on how the cabinet is assembled and any recommendations about how to strip parts whilst causing as little damage as possible. Ultimately the cabinet will be filled, resprayed and then re-decaled so hopefully any minor damage caused can be made good.
I'm looking for advice on the make-up of the cabinet and the best way of going about approaching the task at hand. If anyone has suggestions based on the pictures below then i'd really appreciate it.
The damaged corner with the original MDF sheet in place
MDF removed.
The other corner at the back. Looks like we're missing a 'wedge' from that corner which provides bonding for the corner and supports the leg bracket.
The badly split wood below where the head sits. Note that the plan is to ditch the wing nuts and go back to a roto lock fitting (although the wing nuts could be kept and also used)
I'm also interested in finding out how the original leg mounts are fitted. Mine has three original mounts and then one of the more substantial Bally/William mounts. The originals aren't that sturdy so i'm tempted to replace them, but in order to do this I need to figure how they are secured. They appear to be fitted from behind the corner strip which supports the corner.
And I believe (although perhaps someone can confirm) that the corner strip is held in place by these screws at the corner?
Grateful for any help and/or assistance. Woodwork isn't something I usually do a huge amount of so i'm keen to investigate so I can do as good a job as possible.
