Just recently got a Rocky and Bullwinkle and Friends. Seemed to be working ok for the most part for the last couple days, but I noticed an issue this evening with the SAVED drop targets not resetting, specifically when all 5 have been dropped. If its just 1,2,3 or 4 dropped it appears to reset ok... but once all 5 dropped, the coil fires to reset them but it seems a bit weaker and attempts a few times and gives up. I have also confirmed this in coil test mode, by manually dropping all the targets and trying to fire the coil to reset, and no luck. If I reset the targets manually, then dropping just a few of them and firing the coil again it resets ok, just not when all 5 targets have been dropped. I don't believe there is a particular drop target that is causing the problem, but I haven't completely ruled that out.
This is my first pin, but I have been collecting arcade games for a bit, so I am pretty comfortable working with a multi meter, switches, wiring.
Any suggestions on what items I should take a closer look at would be greatly appreciated!
Cheers!
