Quoted from Kb8yrw:Upper diverter is working good. Trouble I have is the ball shooter has a hard time getting the ball past the first lane. I have adjusted the gate so the ball goes up the center of the "wall" ramp, installed a new spring, insert and tip. All that helped but it still just does not seem to be fast enough to get it there. Maybe it is normal, I don't have anything to compare it to except when I first got it before I changed the tip it seemed to shoot it right up there. The original tip split and fell off which is why I changed it. That led me to change the spring and insert and then another new tip. Is there different types of rubber tips that you can buy? The original looks like the new ones I tried but just does not seem to get it there. The original spring was red and the new one is also red. The rod is straight and does not bind. I gave it a little shot of lube but it made no difference. Am I chasing my tail or should it make it to the third lane?
Yes, do what willie suggested. On the inside of the cabinet is three screws, loosen those (dont remove) and you can move the shooter rod all around as to where it will strike the ball. It may take quite a few tries to get it where you want it, on my Taxi it took dozens of tries to get it perfect.
also, check the shooter gauge where the ball rests, that is the little metal piece with the window that lets you see the spring tighten, make sure its not bent crazy out of whack.
