More info from this article quoted. Check this easy fix first:
"Random Game Resets On JP, LAH and TftC.
During game play, the games Jurassic Park, Last Action Hero and Tales from the Crypt randomly reset. This occurs beacuse the +5 volt line is shorting against the ground backbox metal plate. This grounding plate lies behind all of the printed circuit boards mounted inside the backbox. The metal plate can bow, causing it to intermittently short against one of the backbox circuit boards. This will cause the game to reset. To fix this problem, remove all the circuit boards (label the connectors!), and remount the metal backbox grounding plate to remove the bow. Another solution is to remove the sound board and affix an insulting material to the metal plate directly behind the sound board at connector CN2. This will insulate the metal grounding plate from the sound board (which is the board most affected by this bowing metal plate). Make sure the insulating material is non-conductive, and thick enough so it cannot be perforated. This problem was discussed in service bulletin number 55."
