Quoted from gdonovan:Question: what software version are Robocop owners running? I have 3.5 on mine, I notice IPBD only has 2.9 and 3.4.
I'm trying to chase down a sound problem where sounds for the poppers, inlanes, upper roll overs and the two rebound switches to the left of the poppers will not generate a sound call when initially hit. The MPU is seeing the switch hit and the score increases but at times no sound. If it hits a few times the sound comes up and will continue to work unless the poppers are engaged again and sometimes drop out. Tried swapping sound cable and verified sound roms are good, same as the 3.4 sound roms listed on IPBD.
I have version 3.4. Did not know there was a 3.5.
Sound problems
Turbo sounds: Those cool sounds that come from the slings and pops.
1) My turbo sounds come and go depending on whether I hit some particular switch, or not. I like the turbo sounds and wish they were on 100%.
2) Inlane switch behavior: With a fresh ball on the play field, and the first pass through both of my inlanes, the inlanes will not will not register a sound. On the next pass through an inlane the sound registers correctly and will continue for each inlane pass thereafter. After the Ball 1 drains, the same behavior returns for ball 2 and then Ball 3.
I do not know if any scores are being registered when my inlanes are silent.
Are we talking about the same thing?
