.....So today Ive rememberd that I pulled up the ramp as I was cleaning the playfield under the ramp a lot before adding the protector. So Ive compared the look of my actual ramp with some deatailed images Ive done before working on the playfield. Ive discovered that my ramp looked different at the beginning of the ramp and at the middle of the ramp. So I bend the ramp so that it looks like on my photos again. And what could I say.....I couldnt get up the ramp anymore ...even when I shot perfectly out of motion. So I removed the stronger spring again! Also after adding the lot more weaker original flipper spring I couldnt get up the ramp anymore! So I decreasaed the steepnes too a bit. Wow! Now it works without a stronger spring and only with a tiny little bit steeper ülayfield compared to the steepnes it had before ading the protector.
Looks like Ive bended the ramp a lot too much in upper direction when I cleaned the area under the ramp. After cleaning I recognized that the ramp entry stays above the playfield, because I bend it too much. So I bend down only the front of the ramp down, so that it has contact to the playfield again. Bending only the front down caused a overall less steeper way up the ramp. Because Ive added the protector after cleaning I thought that the problem of shooting the ramp up too easy comes in general from the added protector. But now I know that my wrong bended ramp was the main problem
So if someone add a protector in the future....it should be enough to only increase the steepness of the playfield a tiny little bit to have the same difficult ramp action again as on a playfield without a protector.
Gameplay feels now like playing on a unprotected playfield with the exception that it feels a bit more "buttery" as before. So the feeling is a tiny little bit different. But this difference is nearly not noticeable at all. Could also be a bit an placebo effect because the playfield is a lot more quiet as before now. My robo war had a very buttery feeling even before adding the protector. I dont know how to explain it......feeled a bit like an EM. When I play a system 11 for a time and change after that to my gottlieb its a totally different smoother feeling. Like hitting a steelball (rollergames) compared to hitting a softball (robo war)
Would be interesting if this smoothness was also noticale when the machine was new back then or it comes from years of playing. But I noticed this smoothness also at other gottlieb machines too.....I think they are build like this and is a leftover from times of the gottlieb EM-period.
