Quoted from cooked71:Will it be possible to activate/de-activate family mode without opening the coin door? Like holding both flipper buttons or a certain combo of flipper button hits? Would be really handy in a home environment.
Also, is a headphone jack possible as an add on?
from Fawzma, yes on family adult flipper toggle, see below. headphone, I can't remember what Ben or longhorn said...but I definitely want a headphone jack whether factory and mod afterward
Flipper Code has been added. You can activate this in the main menu settings screen. One is to set it in record mode, the other is for when it’s set. I’ll have to add a 3rd option for operators who don’t want people trying to guess the code.
Flipper code is for changing adult mode while in attract mode so you don’t need to open the door.
When in attract mode, hold both flippers for 10 seconds. The backglass will flash for 3 seconds. left go of the flippers. When in record mode, you are show a screen with instructions on setting the code. Once the code is set, it will flip the setting to “SET” mode and save it on EEPROM.
In SET mode, hold flippers for 10 seconds, BG flashes, let go of flippers.. then enter your flip code when it stops flashing. Entering the code successfully will turn the backglass red when in adult mode, and you’ll certainly hear about it. If it goes into family mode, the backglass will turn green.
