Quoted from FawzmaGames:
There is one.. maybe not so subtle. Depending on match; there are 4 match callouts 2 are adult, and 3 non match callouts
Oh really. Wow I really have to pay more attention.
fawzmagames with the next update will it just be bug fixes or can we expect some more goodies?
Dave - are there plans on adding sounds/music for an attract mode? Also, if the flipper buttons are pressed (on most pins) there is a random sound or snarky comment from the game. I saw a menu item there but so far haven't heard anything.
Quoted from davijc02:
version 21 is bug fixes + hellbound
Thing I need to add still
Implement the new score system
Needs more light/sfx drama
More lighting/Sfx drama sounds awesome!
Quoted from hAbO:
There is, there is a jukebox mode for freeplay. Holding left flipper in attract for 5 seconds will start music.. keep holding to pick a new song. Hold right flipper to cancel out. This could use some more work to make it a bit more user friendly.
Will the robots be in 21 or after?
Loving the fact that it appears the "core" of the game is present and we are approaching the fine tuning to bring out all the goodness
still a bunch of things I want to do, even a new party mode....... just wait and see.
Quoted from GhostThruster:
yes. Robots play a part in this game with V21. Just gotta get far enough to understand why. I do plan on having a score table for those robots as well.
You know all my games are set to three ball, but I may have to turn 5 ball on RZ for a while so I have a chance of getting to Hellbound. I still don't think it'll be an easy feat.
With that in mind, any chance of keeping separate high score tables for three ball and five ball? Or maybe even a way to choose when you press start whether it's going to be a three ball or five ball game? I don't think there are other games out there that do this, but RZ could sure benefit from a novice mode (5 ball, easier settings or something) so when I have groups of people over the not so gifted players have a chance of seeing/doing anything on the game. Biggest complaint I've seen is from younger and less skilled players that it just kills them and then they walk away.
With TnA going crazy, just wanted to leave a note... Kayte has been getting lots of side requests for Rob Zombie... on our end, the game is 100% sold out.
You may want to check with Joe at PinballSTAR. He may have a game left for anyone interested.
Back to work! Trying to keep up.
It would be nice if the jukebox played the next song "automatically" instead of repeating the same one. Sometimes I work on other machines and it would be great to have something to listen to. You could even use the "Dead City Radio" animation. With RZ playing in the background I could probably fix everything in half the time
The other sounds for the flipper buttons would be cool also. Its a feature that I'm just used to seeing on 99% of pins but not a priority.
AC/DC has a cool jukebox/radio feature where it plays all the songs in the game plus live versions as well. There's a radio on the DMD and when the channel is changed you hear static like a radio. RZ already has the sounds and DMD animations so...
V021 is now available
I'll look into adding a way to play the next song in jukebox mode, and maybe something to show it's playing. As for other songs, we are limited to what we have.
Infected flippers are not reversed at the moment. The mode should be stable now. If I don't get any bad reports on Infected mode, I'll reintroduce the swapped flipper effect.
fawzmagames Is there a patch notes list like you had for v20? I know you said mostly bug fixes but you also mentioned the robot stuff being added and something about Hellbound. Curious as to all the fixes and changes.
Edit: found the list on FB
Fixed - show last score routine would interfere with starting a new game. start button handled at end of routine to allow for last score display to function properly
Fixed - AV now at V008, random read error
Fixed - shooting vuk after ball launch and not hitting any switches would flake out the mode select routine
Fixed - mode select now works when using infected mode
Update - If allow match was off, game would try to play a game over clip that didn't exist
Update - VUK fires 3 times at normal power, if eject fails power reduced to 3 to attempts a light jog/unjam. If eject fails again, VUK kicks will pause for 8 seconds so not to overpower the fuse.
Update - Shaker only fired one time on VUK eject and won't trigger again for 10 seconds. This is to reduce stress on the fuse.
Update - servo adjustments going down would roll to 255 instead of 12
Update - drain switch logic was setting plunge timer to fire before a ball was ready on trough switch 1
Update - upper flippers will be forced off anytime they aren't needed
Update - Save light forced off after collecting 500 corpse in 1000c
Update - Balls search on start up kicks ball from lane instantly
Added - Corpse mode, when all balls drained at same time. Corpse count display timer was being killed when it shouldn't be
Yes, in the zip file there is a WHATSNEW file with all the update notes
OUTSTANDING!
It's because of Rob Zombie Spookshow International I've been spending less time on pinside and more time trying to get to hell.
Quoted from rockrand:
Your Commitment to code sets the standard
Agree, Thanks for all the hard work.
what about RZ mystery awards? Build a robot for a mystery award shot. Or hit the hurry up for a mystery award. I feel any help on starting a mode or extra ball would be great in this game.
Quoted from SilverBallz:
That could be fun!
There is already a welfare (is that pc?)extra ball, and one for beating 3 main modes. Robots are for hellbound.
Clear the right lighting targets for a hurry up on the mode start.
Is anyone getting a second ball loading on a ball save?
Yes I did
I'll never get to use my robots
i'll be adding in a score table for them.. so they won't be wasted
ok
I'm reverting the zip file back to V20..
Does this mean don't bother installing 21?
Quoted from SilverballNut:
I changed all the download files already
I have a fix I need to test but not machine.. if you are willing to try it out, send me a msg
Mystery awards are more than just extra balls. Just a thought.
I know.. just being a s.a.
It's not a big deal. I don't Know if it's even a good idea. I was just throwing it out there.
Plus I know you have your hands full and the game really has come together nicely already.
Quoted from Asylum:
Awesome stuff!!!
So is V21 temporarily pulled?
temporary, yes.. I have a fix being tested.
Would it be possible to make entering initials for lowest score of the day optional via menu? It seems to really confuse new players when we have game nights. As a result when I fire up the machine I just start a game and let it drain to put the lowest score before anyone plays. Turning it on and off via menu would be a bit easier as I forget a lot.
Quoted from mackey256:
I like this suggestion - i find it annoying. On location its kind of funny. At home I don't think it has the same effect
Quoted from xbmanx:
I would also turn it off if I could
When low score comes up for initials, I just hit the left button once to select end and it automatically puts "daf". At least that's pretty quick.
Quoted from spandol:
I do the same thing
Not a bad idea, I'll make that an option.
i just do aaa
I always put in my own initials so I have the highest and lowest scores on the table. Thanks Fawzma!
Quoted from Leachdude:
I would suggest the game over music play a bit longer. Just seems way to short.
I agree - it is an awesome addition but I think it could play a little longer.
Respectfully disagree
