I'll try that. I may have the game too steep anyway
That's a good thing to check first. This game is fast enough at the normal pitch, raising it makes a number of crazy things start happening more regularly.
The 'O' in chop is giving me problems and I need to replace the LED. I think these are the Ablaze Premium Ghost Buster LEDs, but if someone can confirm, that would be great. Also, are there any recommendations on where to buy as a Canadian?
Quoted from rask4p:The 'O' in chop is giving me problems and I need to replace the LED. I think these are the Ablaze Premium Ghost Buster LEDs, but if someone can confirm, that would be great. Also, are there any recommendations on where to buy as a Canadian?
If you have the upgraded LEDs from the factory they are these
Quoted from snakesnsparklers:If you have the upgraded LEDs from the factory they are these
http://www.pinballlife.com/index.php?p=product&id=2560
Speaking of LEDs, I got the upgraded LEDs from the factory, and as much as I like color matching playfield inserts in general, you should really think about replacing some of the LED colors in RZ. On all my other games that have single-color inserts, color matching is definitely the way to go in almost all cases. But in RZ, there are so many inserts with printed graphics on the insert that the color match washes it all out.
I saw one of Herg's posts in this thread about changing up some colors. I tried this and it brought out a completely different (better) look - it lets you see the graphics on each insert rather than washing them all out completely. For example, I don't think I even knew there was a chicken wing and a gas can on the upper playfield inserts until I went away from the red LEDs. I didn't follow all of Herg's color choices completely, but I'm pretty close and both my choices and his look FAR better than the color choices that came by default.
I definitely recommend everyone try out color options for any of the printed inserts.
Quoted from Cheeks:Speaking of LEDs, I got the upgraded LEDs from the factory, and as much as I like color matching playfield inserts in general, you should really think about replacing some of the LED colors in RZ. On all my other games that have single-color inserts, color matching is definitely the way to go in almost all cases. But in RZ, there are so many inserts with printed graphics on the insert that the color match washes it all out.
Agreed. I changed a couple of the main mode LEDs from colored to white and it looks much better. The previous blue and red LEDs in there sort of washed out the insert details. It looked OK before but looks great now.
I went with the upgraded LEDs, but the CHOP LEDs have a single emitter under a frosted dome on mine. Maybe there were some changes as the run went?
I'm getting a lot of airballs off of target #2 next to the zombie ramp. Any idea how I can stop this from happening? Thanks
Quoted from bman46:I'm getting a lot of airballs off of target #2 next to the zombie ramp. Any idea how I can stop this from happening? Thanks
Here is how I eliminated air balls from my center target. Removed the foam and put a black post rubber on the back of the target. Had to adjust the switch a bit but it pretty much eliminated all the airballs I was getting.
Quoted from Leachdude:Here is how I eliminated air balls from my center target. Removed the foam and put a black post rubber on the back of the target. Had to adjust the switch a bit but it pretty much eliminated all the airballs I was getting.
I will look into that thanks
Any tips for getting a game to post pass better? I really want my RZ to have a crisp post pass given how much you can be punched for missing shots and right now mine does this goofy lob it up and then bounce it over thing. Flipper strength? Rubbers?
Quoted from rask4p:Any tips for getting a game to post pass better? I really want my RZ to have a crisp post pass given how much you can be punched for missing shots and right now mine does this goofy lob it up and then bounce it over thing. Flipper strength? Rubbers?
Some games just arnt designed for post pass. All depends where the slingshot are mounted.
Have to stick to bounce pass and drop catch
Quoted from Mitch:Some games just arnt designed for post pass. All depends where the slingshot are mounted.
I totally agree, but I saw the Pinball Undesirables stream and their machine did nothing but clean passes. Idk, I'm going to play with it this weekend and see if I can't get a better solution than what I have now.
This is right, some games are near impossible. Can't recall if RZ is not ...
You can always use alternate methods. For example, if your ball is on RZ left flipper, shoot the ramp, lift the flipper and let the ball flow over to the right flipper.
rd
Mine wont post pass at all. I either alley pass or use ramp to transfer
Quoted from Leachdude:I use Titan thin flipper rubbers, they made a big difference to my game, passing and shots.
Are they less "sticky" than the stock flipper rubber? Any reason you chose the Titan thins over regular Titan rubber? I would like to try some different types.
Quoted from snakesnsparklers:Are they less "sticky" than the stock flipper rubber? Any reason you chose the Titan thins over regular Titan rubber? I would like to try some different types.
I had Titian translucent flipper rubbers to start, I liked the look of them but they were way to bouncy, so I figured I would try the thin translucent and I really like the look and the way they play on this game. Feels like more control on the shot to me.
playing superbeast tonight, hit the sneak attack,,, didn't even know that was a thing. The code is awesome on this pin, and there is more to come!
Quoted from Deafcon:playing superbeast tonight, hit the sneak attack,,, didn't even know that was a thing. The code is awesome on this pin, and there is more to come!
What is the sneak attack?
Quoted from rockrand:I was told v20 last Monday,I guess he ran into more bugs
Quoted from Cheeks:What is the sneak attack?
Instead of shooting the ramp 4 or 5 times, one shot to another spot finished the mode right away.
Quoted from rask4p:I think I just heard a Ben Heck call out while I was bashing our favorite clown...
"Ben Heck? Never heard of the @sshole."
Maybe my favorite quote in the game.
Quoted from davijc02:Speaking of new code anyone heard any rumors on when to expect it?
Buy an apron mod and when he ships it to you, you will get the new code
Seriously I haven't seen any dates or estimates. Instead of doing two releases it sounds like they decided to throw everything in it and do one major one.
Is the apron mod actually for sale, like I can order one and get it? Or is he working through some waiting list? I thought he only released a few into the wild at this point.
Quoted from Cheeks:Is the apron mod actually for sale, like I can order one and get it? Or is he working through some waiting list? I thought he only released a few into the wild at this point.
He posted on facebook last week to PM if you wanted to try out the beta shopping cart system so I ordered one through that. He should be launching the shopping cart to his site anytime now and then you can order it by paying in full or with a deposit.
Not taking mass orders, only those willing to wait till the main piece shows up so I can ship.
So many things have changed I stopped tracking them. Last check was in the 150 range for fixes/changes.
This will be worth the wait, and this isn't the last update
Quoted from FawzmaGames:Not taking mass orders, only those willing to wait till the main piece shows up so I can ship.
You good sir are making me a happy RZ owner! Mine just arrived yesterday and I'm hoping to unbox tonight and play a ton so I can really appreciate all the changes.
ok in need of a little help. Excuse me if this seems "Noobish" But this is only my second pin. I bought this underlighting kit from a vendor at a con. He said it might not be a direct plug and play on the RZ but definitely should be able to work just fine. So heres what im working with. Any help on how i should go about getting this to work would be appreciated.
Quoted from bgwilly31:ok in need of a little help. Excuse me if this seems "Noobish" But this is only my second pin. I bought this underlighting kit from a vendor at a con. He said it might not be a direct plug and play on the RZ but definitely should be able to work just fine. So heres what im working with. Any help on how i should go about getting this to work would be appreciated.
No, not a direct plug and play. That's a typical Stern molex. With Spooky, you need a different adapter that plugs directly to the board.
You really have two options. You can buy all the parts from Pinball life which should be just a couple of bucks. I can link to what you need.
Or, you can mail me the undercab lights and I'm happy to do it for you. I did the same thing with the BriteButton LED flipper lights.
No big deal either way.
So I got my game unboxed and played several games and I'm happy with my purchase and had alit of fun with the machine. Current code is quite buggy but with an update hopefully real soon this should take care of a lot of problems.
Only issue that I'm really noticing is that the right living dead girl target takes a really good hit to activate. The left switch works normal. What's an easy way to adjust thins so it activates a bit easier. Could it be the foam they placed behind the target interfering a little?
Quoted from davijc02:So I got my game unboxed and played several games and I'm happy with my purchase and had alit of fun with the machine. Current code is quite buggy but with an update hopefully real soon this should take care of a lot of problems.
What number did you get? Go into the main service menu to adjust sensitivity.
Could need a simple adjustment. Use a leaf switch adjustment tool to slightly bend the switch as needed so it operates properly.
Quoted from Mudflaps:No, not a direct plug and play. That's a typical Stern molex. With Spooky, you need a different adapter that plugs directly to the board.
well i appreciate the offer. However its probably easiest for me to just get the parts i need other then go through mailing it out. Could you help me get the right stuff then where i need to power the lights.
Again i really appreciate the help!
You need:
http://www.pinballlife.com/index.php?p=product&id=1590
http://www.pinballlife.com/index.php?p=product&id=1594
Highly recommended (for additional items like shaker, topper, etc):
http://www.pinballlife.com/index.php?p=product&id=4385
Cut existing molex. Using the IDC tool, attach red & black wires to appropriate location on connector. Plug into board.
Quoted from Grizlyrig:Happy to announce that RZ293 has just been delivered!
-Mike
Congrats dude! We're just on time for a big code release!
Quoted from davijc02:I thought I was getting 294 but mine was labeled 295 when I received it
Huh. I'm supposed to be 295.
Quoted from Shenanigander:Huh. I'm supposed to be 295.
Yeah I didnt even notice until I was cleaning up all the shipping materials that mine was listed as 295. I was under the assumption that I was 294. Not sure what happened or if it really matters. If you happen to get shipped 294 it should also have all factory mods.
I will be opening tonight. Originally was 292 but outside tag shows 293. I'm excited no matter what the number is.
-Mike
Quoted from Grizlyrig:I will be opening tonight. Originally was 292 but outside tag shows 293. I'm excited no matter what the number is.
-Mike
Make sure you don't need to be up early for anything the following day or just be prepared to do whatever you have to do dog ass tired! I got mine all set up around 9pm and played past midnight.
The game is super fun and kicks your ass! I couldn't resist hitting the start button. Also awesome because we both just received ours and the new code is on the horizon. I hear it is a substantial update and they still have atleast one more update they plan to complete
This page was printed from https://pinside.com/pinball/forum/topic/rob-zombies-spook-show-international/page/171 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
