(Topic ID: 130434)
Rob Zombie's Spook Show International
By Russell
  • 10,479 posts
  • 599 Pinsiders participating
  • Latest reply 7 days ago by JOESCHALL
  • Topic is favorited by 104 Pinsiders
There have been 1,193 images uploaded to this topic. (View topic image gallery).
7 key posts have been marked in this topic (Show topic index)
There are 10479 posts in this topic. You are on page 147 of 210.
#7301 2 years ago
Quoted from bridgeman:
Received my blades from pinball side mirrors. I notice they do not fully cover due to stepped cut out in back. Is this what others have as well? Trying to see if I did not get correct ones. Have not heard back from PSM yet. Here's pic.
That's not too bad. I bought the official pinblades and believe me they are far from custom fit. At least mine could be trimmed somewhat I suppose. I wanted to get the mirror blades but after sending 4 emails regarding international shipping with no reply I gave up and got pinblades instead. All I can say is, whilst we have both bought products that aren't exactly a perfect fit....it's far better than black sides.
#7302 2 years ago
Quoted from Dutts:
That's not too bad. I bought the official pinblades and believe me they are far from custom fit. At least mine could be trimmed somewhat I suppose. I wanted to get the mirror blades but after sending 4 emails regarding international shipping with no reply.
Thanks for the response. I guess they are not cutting custom RZ blades and must be using something close. Their responsiveness definitely lacks if non existent.
#7303 2 years ago
Anyone know the most recent pin number out the door at Spooky?
#7304 2 years ago
Quoted from zombywoof:
Am I the only one who immediately hears Black Sabbath's Nativity in Black whenever he reads the initials NIB? In any case, #209 came off of the truck today. It's my first new pin. In fact, it's my first one that was built more recently than the Reagan administration I bought RZ in part because of the homage to old school game-play, but more importantly, I bought it because I really appreciate the Spooky story.
Sláinte
Looks like #209 was delivered a few days ago.
I'm starting to get excited only 27 more until mine ships!
#7305 2 years ago
Mine was shipped on Thursday, #217.
#7306 2 years ago
Quoted from princea56001:
218 is finished, picking it up on Thurs.
#7307 2 years ago
Quoted from Dutts:
I didn't realize the"official" ones were available yet... are these from Spooky or the ones from Tilt?
#7308 2 years ago
Quoted from emkay:
Yep from Tilt.
#7309 2 years ago
Just realised yesterday that you can achieve HO1KC twice in one ball. You just need to hit the drop target twice each time to qualify lock the second time around. Had no idea this was implemented, so cool. Have racked up nearly 500 games in the last 3 weeks and haven't lost my lust for it yet. Starting to pull off orbit shots more often when it counts but over all still hard as HELL!.. But fun as F#$K!
#7310 2 years ago
Anyone else with a RZ have any issues with the ball getting stuck in the orbit behind the drop target? For me, it only happens when it circles the orbit very slowly. It also get stuck HARD. I have to lift the pf in order to free it. Any suggestions? I think it might be getting hung on on a switch but I haven't checked that yet.
Similar to every other NIB pinball I have bought, there are a small number of tweaks required to get the game dialed in. Some folks freak out over this (drama queens) but I just make the adjustments and go back to playing.
Starting to understand the rules a bit more, and as expected, the game keeps getting better and better. The taunts by Sid Haig are hilarious...Hands down, this game has the BEST call-outs of any pinball to date (IMHO).
#7311 2 years ago
Quoted from PersonX99:
I've never had a ball get stuck in that orbit, but I have had a ball (multiple?) smash one of the switches under there, leading to all the prongs touching and causing issues with the upper playfield at times (WHAT? would only start on a 2nd attempt, gas or chicken not always registering, etc.). Fixed after lifting the upper field to bend the pins back.
#7312 2 years ago
Quoted from Medisinyl:
Same happened to me. The switch was in the same row as one of the trough switches so I couldn't even start a game as it couldn't detect all balls present with the upper PF switch short. I was able to use an electricians wire fishing hook to reach underneath and pull the tab back without removing the upper PF. The other switch is not accessible though and would require upper PF removal to correct.
#7313 2 years ago
Yes, there are a couple of reports in this thread.
https://pinside.com/pinball/forum/topic/rob-zombies-spook-show-international/page/120#post-3329829
#7314 2 years ago
Thanks.. Looks like all I need to do is adjust the guide a little bit..
#7315 2 years ago
Oh hey, how'd y'all know what I was working on today? I haven't found a spot where the guide needs adjusted yet but the ball will sit up on this switch if you send it there slowly enough. I've gotten good at sending a second ball up after it to knock it loose, only dropping the playfield glass halfway down and leaving the coin door open so I can return my ball to the shooter lane and resume my game. I think the one on location near me has been down for the same issue the past week or two.
#7316 2 years ago
See how the switch isn't quite centered in the lane? I'm wondering if a little ball spin makes it bind up on the switch, because when it's in there good I can't shake it loose. That's the next adjustment I'm going to try.
If you're going in, it's much easier to disconnect all the upper playfield and ramp wire connectors under the playfield before you start turning screws. The red/orange/black wires to the clown servo don't seem to be easily disconnected. Same with the LDG lighting but it unscrews from the assembly.
#7317 2 years ago
In my case, yeah, I just bent the ball guide slightly.
#7318 2 years ago
My RZ gets stuck balls in the inner orbit as well. Only sometimes and only on weak shots. I think it's the switch. I've tried adjusting the switch more than once, and I'm pretty sure my adjustments have helped to lessen the frequency of occurences, but I have yet to find the sweet spot that cures the problem 100%. You can't bend the switch down too much or it won't register.
I do have 1 helpful tip though. There's a much easier way to free the ball. No need to remove the glass. Just left the pin a little bit from the right side (tilting toward the drop target side), set it back down and the ball will roll gently out. I can typically do this without tilting and continue playing the ball.
#7319 2 years ago
What kind of switch is used on the underside? I know cherry used to make three or four different button weights. Meaning less or more pressure to activate it. Also is portportinal to amperage. Have you ever noticed the button a different color. But those were full sized micro switches.
#7320 2 years ago
Just noticing that if you are in a mode such as Dead city Radio, and you trap the ball, all the "indicator" lights go off. If you are just learning the rules, can be off-putting. Happens with most ball traps too. Is it necessary?
#7321 2 years ago
It is almost like the switch needs to be a different shape as it seems to get stuck on the high point of the switch and the start of the slit in the PF.
#7322 2 years ago
Quoted from dendoc:
Agreed, very off putting.
#7323 2 years ago
Quoted from dendoc:
I'm going to get rid of this "feature" when I get the score display implemented properly.
#7324 2 years ago
Quoted from paulywalnuts23:
You could probably replace it with a Stern type switch with a rounded lever.
rd
#7325 2 years ago
Quoted from rotordave:
rd
That was what I was thinking, at least with the shape.
#7326 2 years ago
Only thing we would need to look at is how that affects the balls coming though that return entering the top of that orbit.
#7327 2 years ago
try turning the switch around
#7328 2 years ago
I originally had a problem with the ball guides being too narrow, so you may need to take the ramp off and check that. I was still having issues with slow balls, and found the problem is the spooky switches are tight enough to hold a ball there. So I replaced the switch with a WPC era lane guide switch. It takes much less force to close the switch so the balls don't get stuck. After doing this I had a ball try to stick once, but a gentle rocking of the game (didn't even tilt) and it came out. I'm considering the problem on my machine solved.
#7329 2 years ago
Quoted from SilverballNut:
Which P/N switch did you replace it with for future reference?
#7330 2 years ago
Quoted from snakesnsparklers:
I believe it was #5647-12693-19. However, my workbench is currently full of wiring harnesses and switches (building/restoring a CCC) and I just grabbed one. You'll notice the lever is on the adjustments closer to the switch side. This also helps the switch activate with less force. Instead of trying to resuse the plastic switch bracket, I used an older williams metal one too. Again because I have about 50 of them sitting on my workbench so I assembled (add a diode) and adjusted the switch before going to RZ and soldering it in place. I threw the original where the coin box should be. Still need to order a box for the heck of it.
Even very fast balls through the lock loop register all the time which was also an annoyance I had, but harder to prove. I'm probably going to change any other hidden switches too when I get around to it. I believe the hidden passage has a potential to catch a ball, but it shakes out of there easier with the alignment it has (parallel to the sloped playfield). Pretty sure changing to these 'better' switches will stop any chance of it getting hung up.
#7331 2 years ago
A horizontal switch i a designer error in a pinball machine. i hope they don't do that again.
#7332 2 years ago
Quoted from pinballwil:
Same thought crossed my mind. Those slots in the ball guide lead me to believe they intended the switches to be parallel to the playfield at one point.
#7333 2 years ago
Quoted from emkay:
An opto would be the correct answer if you're going to have one. No playfield slot or switch to get the ball hung on.
#7334 2 years ago
I think you'd find 99% of orbits use a normal switch, no different to RZ.
I think the switch is too high spring tension, and the lever type doesn't help.
I am pretty sure I have a new stern type round lever switch at home, I'll grab it in the weekend and swap it over and see what happens.
rd
#7335 2 years ago
We have played well over 1000 games on mine (#141) and for what it's worth, I can only remember maybe 2 or 3 times the ball has ever got stuck in the corpses lock orbit. When it did i don't remember much more than a nudge to get it free.
I apologize if Fawzma has ever answered this, I know it's been asked several times, will the corpses drop target progression continue to reset after LDG? Might be a nice option in settings if possible. My wife loves the game and that is because how you start the add a balls in for LDG, however she has never gotten close to Corpses. I think the drop not resetting could help to allow some of us, by choice, more easily get there. Lock should go out during LDG, just after return drop to position it was.
Another one is the ability to restart a game before Ball 3 drains?? Not sure why this would not be a function?
#7336 2 years ago
Because it's cheating? Haha. I don't see the need for it. I've turned it off on all my games that have it. The worst thing in the world is a game restarting because of the start button being pressed during a competition or an amazing game.
#7337 2 years ago
rd
True, but those switches are at the beginning or end of an orbit and parallel to the slope of the playfield. This one is at the top most arc and perpendicular to the slope of the playfield (it's almost horizontal). It's really a bad location for a mechanical switch.
#7338 2 years ago
Quoted from chuckwurt:
The option would be nice.
#7339 2 years ago
Play all balls like they were your last, never give up on a game. Some of my best games have been when ball one drained quick.
#7340 2 years ago
I do appreciate the motivation, but why not a feature? It's not like it allows you to pad a score? Also would be nice when a youngster starts a 4 player game.
#7341 2 years ago
Oh I don't have a problem with the option.
#7342 2 years ago
Looks correct- it's not the greatest, cleanest, fit. But it certainly gets the job done
#7343 2 years ago
218 out the door today, along with 15 others.
Big Thanks to everyone at Spooky!
#7344 2 years ago
One of 16 games shipped was a Domino's.
#7345 2 years ago
I’m still getting to know the game, but am really pleased so far! Spooky is the real deal.
The shots are pretty tight, and just slightly off from where I want to shoot instinctively. With the spread-out pops and extra slings to add chaos, there is really no room for much slop. I’m not very used to playing with silicone rubbers and the flippers are really bouncy.
I have had no balls stick in the orbits, even at very slow speeds. The first night I had the game I did have one get past the rubber on the right sling during LDG add-a-ball. It took me ten minutes or so before I finally found it.
I am seeing a couple of minor quirks. On two or three occasions I got the Ball Saved graphic immediately after the ball was ejected into the shooter lane. Also, I definitely have had House of 1k Corpses lock the ball when the drop target was still up (running v19). I'm guessing switch issues. Any suggestions from those who have already dialed in?
#7346 2 years ago
What's happening is, you dropped the target and the lock is waiting. You start some other mode, then finish. Drop target goes up (need to check for the need). You shoot behind the target and the lock is granted, because technically it was still waiting. I don't have a machine in front of me, if someone would like to confirm.
#7347 2 years ago
Quoted from FawzmaGames:
Sounds right .From what I have noticed the game lets you know when you can sneak a lock in there by having the number of the ball to be locked flashing even though the drop target is up .
#7348 2 years ago
That sounds logical. I'll pay closer attention next time I see it.
#7349 2 years ago
Here's a video, yes this is correct(sorry for the poor camera work).
#7350 2 years ago
Also noticed what appears to be a bug. Once you get through 1000 corpses and you're working on the second round of knocking down drop targets. The 1st lock light on number one doesn't appear to flash in sequence until drop is hit.
4,400 (OBO)
Chattanooga, TN
CzTV Mods
$ 495.00
MI Pinball Refinery
$ 107.95
Hookedonpinball.com
