(Topic ID: 337400)
Roadshow outhole solenoid keeps firing
By Boo-Ya
7 days ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 7 days ago by Boo-Ya
#1 7 days ago
My outhole solenoid wont stop firing? It keeps kicking all the balls to the plunger. I cleaned off all the diodes on both of the opto boards and checked the ball switch by the plunger(OK) but it still keeps firing? Any ideas?
#2 7 days ago
Quoted from Boo-Ya:My outhole solenoid wont stop firing? It keeps kicking all the balls to the plunger. I cleaned off all the diodes on both of the opto boards and checked the ball switch by the plunger(OK) but it still keeps firing? Any ideas?
Have you run a switch test in the diag menu? What did it say?
#3 7 days ago
Assuming correct number of balls in it.
I would check the row and column the ball jam opto is on. That is the last opto a ball goes by going up to the shooter lane.
A good chance on the same row or column there is a switch wired wrong, diode on backwards, or a short to switch wiring or lugs.
#4 7 days ago
I ran a switch test in diag: T3-41 Through Jam
42 Through 1
43 Through 2
44 Through 3
45 Through 4
T3-48 Hit Ted
T3-12 Dozer Down
These particular numbers indicate a flashing "open/close" message back and forth.
$ 299.95
Pin Stadium Pinball Mods
Led
$ 399.95
Led
$ 105.00
Arcade Upkeep
Other
$ 9.90
pinballmod
Toys/Add-ons
This page was printed from https://pinside.com/pinball/forum/topic/roadshow-outhole-solenoid-keeps-firing and we tried optimising it for printing. Some page elements may have been deliberately hidden.
