Hi. This does not seem to be my week for optos. I'm curious if some of you think my multiple issues are related or unrelated.
Issue One:
For some time I've been having an issue with the middle flipper on Roadshow. When the left flipper button is engaged the middle flipper continually flips. It's about a flip per second, full force. I figured it was EOS switch, but switch test says otherwise. Then I thought it was a bad coil on the hold side. Flipper test says otherwise. Hmmm...
Issue Two:
Then Roadshow's flippers in general seem to be weak intermittently. In test mode the flip full force. In the game, often not so much.
These two issues lead me to believe that either I've got a bad LM339 chip in my fliptronics board or that my optos are old and need replaced. I cleaned them and no help with the constantly pulsing middle flipper, but it did seem like the lower flipper strength issue got better (ish).
Issue Three:
Now I have what appears to be two failed optos on my bulldozer. In switch test if I put a piece of paper in front of up or down then they read closed. When they are open, they read open/close/open/close/open/close in very fast succession.
So what gives? Where would I even start (I do have three replacement optos coming from pinball life)? Are these issues related in any way or just bad luck this week for optos?
Thanks in advance.
Dan
