(Topic ID: 130546)
Roadshow GI lighting out
By Bubbatom
5 years ago
  • 21 posts
  • 8 Pinsiders participating
  • Latest reply 5 years ago by Brtlkat
#1 5 years ago
Hey there guys,
Was playing some Roadshow tonight and halfway through a game (while the shaker was going) the GI lighting on the left side of the playfield all went out.
I suspect that a cable may have loosened somewhere due to the shaker? What exactly does a connector for the GI look like and where may I find it on the machine?
Thankyou, Tom
#2 5 years ago
Search engines a good start. Type in your issue and press enter. Sounds like burnt gi header pins/connector on the driver pcb. Very common issue. http://www.pinwiki.com/wiki/
#3 5 years ago
Check j120/j121 on the driver board for burnt connectors, replace BOTH with molex style housings and trifurcon pins. Fuse for that side is likely gone as well.
Common issue.
#4 5 years ago
Also look at j115 for burnt connector/pins
#5 5 years ago
Quoted from Bubbatom:
Hey there guys,
Was playing some roadshow tonight and halfway through a game (while the shaker was going) the GI lighting on the left side of the playfield all went out.
Thankyou, Tom
Happens every once in a blue moon with mine. The shaker shakes loose a connection. I forget which one it is but just turn her off and push in the ribbon cables on the boards. Should get her going again.
#6 5 years ago
Ribbon cables???? They have nothing to do with GI's
#7 5 years ago
Quoted from Brtlkat:
Misspoke.
#8 5 years ago
In this case (only left side GI out) it is likely J115,J120,J121 but GI and ribbon-cable do have something in common.
- data 0-4
- GI enable
- Zero Cross
- Blanking
#9 5 years ago
Mine has the same issue, only the left GI goes out here and there. I've check the pins and the are good. I haven't taken the board out of the backbox yet to check solder joints.
#10 5 years ago
Alrighty, cheers guys.
I had a quick look today and I'm just a bit unsure of which cable is the left GI cable? I assume it's on the driver board?
Thanks again.
#11 5 years ago
Yes, on the driverboard bottom-left but don't know the wire-color of Left GI
#12 5 years ago
Quoted from Atomicboy:
Common issue.
Just a thought: If the OP is asking what a GI connector looks like, this info ^^^^ is probably going to be like Mandarin Chinese to a 6th-grade dropout from Pocatello.
#13 5 years ago
Quoted from purplemunkydishw:
Having it go out every once in a while is a classic sign of cracked solder joints. Pull that board and reflow!
#14 5 years ago
Cheers zaza, that table helped a lot!
I found what is most likely burn marks on J121 (the lower of the two connectors) on the left most pin.
I'm just wondering what to do from here?
Also, what fuse would have blown if any did as a result of the burnt pin? The left lower-most fuse on that board (closest to J121) seems to have a break in it's filament.
Thanks for the help guys, this is my first experience with playing around inside the backbox.
Currently, photos don't seem to want to upload. I might try again later.
#15 5 years ago
Ok, from picture IPDB and manual it seems Left Playfield GI is GI#5 violet.
Found a great picture on pinwiki of this GI-string.
#16 5 years ago
Cheers zaza, this is easy to read!
So the highlighted fuse seems to be blown and the leftmost pin (11) on J121 appears to be burnt.
What to do now? Obviously I need a new fuse, but how do I go about repairing the connector?
Thanks again,
Tom
#17 5 years ago
Very much depending on your skills, solder-tools and how much it is burnt.
The machine is 20+ years old and if connectors are still original, they can use some upgrade by now, Male and Female
http://www.pinwiki.com/wiki/index.php?title=Williams_WPC#General_Illumination_Problems
#18 5 years ago
Thanks zaza,
I'm thinking I will probably change all of the pins on the connectors.
Now all I need to find out is what sort of fuse I need to replace the burnt one with!
Cheers,
Tom
#19 5 years ago
The fuse is a 6,35 x 32 mm 5Amp S.B.
#20 5 years ago
Thanks zaza,
Now I can get cracking!
#21 5 years ago
Could have gotten cracking a week ago post #2 says the same thing, Just have to read some.
4,500 (OBO)
Brook Park, OH
