(EDIT) replaced fuse F112, now all coils fire and blows F112 on startup. Any ideas?
Quoted from Staythirsty:I just put in a repaired board
What board did you put in?Did you check all the fuses?All the connectors on the boards?
Thanks Mike, replaced F112 game worked great in test mode. But when I start it with the door shut all coils fire and blow F112.
One flasher is stuck on and the others don't work in test mode. Also, Dmd starts all funky then works fine.
This page was printed from https://pinside.com/pinball/forum/topic/road-show-tech-coils-and-flashers-help-needed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
