(Topic ID: 243541)
Road Show Slam Tilt
By LargemouthAss
6 months ago
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 5 months ago by LargemouthAss
    #1 6 months ago
    I have a Road Show that has been resetting mid game, I bought the kahr pro daughterboard so it would tell me if the problem was the 5v or the 12v. I put it in and it shows that the 5v is getting too high AND too low and that the 12v is dropping below 9v. After asking around I realized that I might be dealing with a different problem entirely as the game does not fully reset, rather the display gets diagonal lines, the flippers stop, and the game goes back to attract mode. So the game is not resetting rather it is slam tilting.
    I noticed that this is happening whenever I hit the white stand up target (81) during normal game play. I went in to test mode (with the door closed for full power) and the stand up target registers and does not slam tilt. I tried the T4 solenoid test and let it run while pushing on the target, all solenoids fired and the game did not slam tilt. During normal gameplay the stand up target causes a slam tilt every single time it is hit.
    I have re-seated all the connectors on the boards and there is no battery corrosion or obvious wear on the boards. They look great.
    I have ordered a new stand up target just to be sure and I will install it when it arrives. Should I be concerned about the kahr daughterboard voltage issues or is that typical with a slam tilt? Will replacing the target resolve this issue? What else should I check? Any and all help is appreciated.
    Here are pictures of the wiring for the switch:
    #2 6 months ago
    Slam tilt is on your switch matrix.
    Sounds like a normal switch matrix issue. Switch wired wrong, diode on backwards, or a short to switch wiring.
    If it just started - go over what you did last. If it's been doing it for awhile, go over all your switches and wiring.
    #3 6 months ago
    Quoted from LTG:
    I have had the game since February and all I have done is add a colorDMD and replace switch 72 which is on a different column and row on the matrix. Could that be the problem?
    #4 6 months ago
    Quoted from LargemouthAss:
    Did you wire it in right ? Same as all your other switches. White wire and black end of diode to a lug, green wire to a lug, silver band end of diode to a lug.
    Easy to check and compare to other switches.
    #5 6 months ago
    That is how I wired it! I will look around the playfield again tonight and see if I can find any switch issues. Thanks!
    #6 6 months ago
    I haven't got any ideas. Just wanted to say I really like your user name. Made me laugh!
    Anyway, listen to LTG, he's greatly knowledgable and invaluable around here.
    #7 5 months ago
    Turns out there was a short on the red "magic" target. Got it up and working fine thanks to Pinball Paul! (I looked everywhere for a short but did not know exactly what to look for, won't make that mistake again)
    $ 38.00
    $ 9.99
    $ 400.00
    Great American Pinball
    $ 159.99
    $ 69.50
    $ 5,799.00
    Operation Pinball
    $ 7,499.00
    Flip N Out Pinball
    Metal-Mods
    $ 29.95
    £ 89.00
    PinballToys
    CzTV Mods
    $ 175.00
    Professor Pinball
    $ 89.99
    $ 249.99
    Pinball Mod Co.
    $ 7,499.00
    Classic Game Rooms
    Yorktown Parts and Equip
    $ 98.00
    $ 76.95
    $ 23.75
    The MOD Couple
    $ 79.95
