Hello everyone. Recently I picked up a Road Show that definitely has a lot of issues. However, the one issue that’s really stumped me is with the playfield. For some reason, regardless of if I move the wires in the back, or if I try to adjust anything underneath it, will not sit flush with the receiver. I should also note that it seems to be oddly tight within the cabinet, and makes a screeching noise when being pulled out or pushed in. It also appears to be catching on the left plunger rod, therefore damaging it unless you pull it back when pulled up (which does not seem right at all). I have talked to some people, and all seem to be lost on what the issue could be, or have never experienced it themselves. Has anybody else experienced this issue before, and if so, how do you handle this situation? Attached below are some pictures of positions I’ve gotten the playfield into. Thank you guys.
