Fellow RS owners … I’m hoping one of you can help me.
If your RS has a Power Interlock switch inside the coin door can you pls help me determine where the wires from each lug of the switch go to/come from?
A previous owner completely removed the switch and did some other electrical hacks. There are hacks on top of hacks and I’m uncertain how to re-install the switch (which I want to do to make safe for a future owner).
As far as I can tell, I THINK the switch sits between one pair of the white-red and black-yellow wires coming from the transformer and going to J102-2 (W-R) and J102-9 (Blk-Y) on the power driver board.
There’s a second set of white-red / black-yellow wires that I THINK run directly from the transformer to J102-4 and J102-6, respectively, without passing thru the interlock switch.
Again, there have been numerous hacks/repairs to this machine and I’m not certain about my assumptions above. If any one can confirm them or correct them, I'd be extremely grateful.
