Hey there guys i had a few couple of questions. I'm purchasing a road show next week and i wanted to change some of the lights out. Where the map trim is i wanted to replace with red, white, and blue light. Overall i wanted to reduce some of the white light and replace them and make the pin more rainbowy(if that makes sense). When changing out lights is it better to do the whole pinball? or is it ok to just change out whats needed? Is it better to purchase a kit or buy the bulbs separately(cometbulbs). My indy has a pin-bulb kit and it looks great(came with it). I just dont know where to start going about replacing stuff.
Second question is my pop bumpers. I wanted to replace them so they are red,white,blue. Would i need to buy bulbs matching the bumper color or would keeping the clear lights be fine. Also what would you guys recommend as really good replacement bumpers?
Third im about to order a set of mirror blades for PDI. Ive heard really good things about them so i thought i would give them a shot. I've watched videos on installing blades. Do the blades go over top the screws on the side or do i need to unscrew them out? I plan on using double sided tape for the meantime.
Fourth i also wanted to put on Backboard Decals. How hard is it do that and would i need to remove the backboard? Is how do i do that.
