I was doing work on the main board and when I put the board back in I accidentally got the 18VAC Gray-Green wire on J4 pinched under the top left mounting screw which took that 18VAC to ground for a few seconds when I turned on the game. Now I barely hear the sound and has crackling/static also. Did I fry an audio amp or what could I have possibly screwed up on sound board?
