(Topic ID: 83745)
ROAD SHOW CLUB (Hard hats required on site)
By webdiddy
9 years ago
  • 3,608 posts
  • 428 Pinsiders participating
  • Latest reply 1 day ago by pudealee
  • Topic is favorited by 170 Pinsiders
There are 3,608 posts in this topic. You are on page 72 of 73.
#3551 62 days ago
Quoted from Bakchos:
Hi group,
I might have a roadshow this Sunday, I'm already looking for mods...
I was looking at pin2dmd and I can't find if the color files are available or just in wip version.
Anyone knows?
https://vpuniverse.com/files/file/5849-red-teds-road-show/
#3552 62 days ago
Thanks, but that's a colordmd
I want to try pin2dmd for this one.
My bad, I have no experience with pin2dmd.
#3553 62 days ago
Thanks, that's the file I use on my virtual pinball.
But in the forum it says it's not for the real pinball, just the virtual.
I will try to search the forums.
#3554 62 days ago
SOLVED - Just experienced an odd situation. I fired up the machine for the first time in a few days, and as soon as the ball hit the shooter lane, it started racking up points. Any time I hit the flipper (either one) it would rack up points. It sounded as if I were shooting the spinner. On one occasion it would load two balls into the shooter lane. Any idea what might be going on?
The funny thing was it was on Miami, and I had a 300M ball.
#3555 62 days ago
Hi. Mine has a Pin2dmd. Looks fricking awesome. !!!
#3556 62 days ago
Quoted from pudealee:
Most likely a stuck switch. You need to test switches in “T2 Switch levels”. And locate the active switch. Good luck
#3557 62 days ago
Quoted from Santis:
Thanks. When I just now turned the machine on I got the following message - "GND. SHORT ROW 1 IS STUCK CLOSED."
When I do a T2 Switch Level test I get the following: Dozer Up (switch 15), Always Closed (Switch 24), and Trough Jam (Switch 41)
#3558 62 days ago
SOLVED - I had removed the coin mechs that came with the machine. I set them in the spot where the coin tray was supposed to be. Over time one of them shifted and was touching the slam tilt switch that is on floor of the machine, close to the tilt bob. All is well with the world!
#3559 61 days ago
Has anyone else used an actual small boom box to replace the radio? Working on it now, probably going to go with Yellow, adding GI light to the speaker grills and a RED LED to the middle to replace the one the was on top of the radio.20230117_185416 (resized).jpg20230128_144509 (resized).jpg
#3560 61 days ago
My Road Show was delivered yesterday. I have never played a game with such a strong shaker motor! Damn thing feels like it's trying to tunnel it's way through my floor. Such a fun game!
#3561 61 days ago
Quoted from PTHermes:
Has anyone else used an actual small boom box to replace the radio? Working on it now, probably going to go with Yellow, adding GI light to the speaker grills and a RED LED to the middle to replace the one the was on top of the radio.[quoted image][quoted image]
Looks like you had the Dewalt or Milwaukee version to choose from.
#3562 61 days ago
SOLVED - I had
Sweet!!!
#3563 61 days ago
Quoted from Merendino:
Mine is powerful too. Kind of feels (and sounds) like it wants to shake the cab apart. This is my first game with a shaker, is there a way to dial it down a little bit?
#3564 61 days ago
Quoted from polyacanthus:
There is a setting in Adjustments for the shaker motor strength - check the manual if you don't see it.
#3565 61 days ago
Quoted from Oscope:
The problem is even on the weakest setting its still a bit too much imo. I would love an even weaker setting, too bad Soren didn't coded this into the latest official game ROM.
#3566 60 days ago
Quoted from Lhyrgoif:
Have you rotated the weights in the motor to be at a right angle?
#3567 60 days ago
Quoted from germsinc:
On my shaker there is an indent for the screw, If I try to screw it in another angle the weight gets loose after a while. If the motor rod had several indents at different angles that had been great.
#3568 60 days ago
Quoted from Oscope:
Found it, thanks. Changed it to "soft" which helped. My guess is the unit needs some work too, I'll have to check it out.
#3569 60 days ago
I got a Road Show project a while back. I pulled everything apart and cleaned/repaired it all. Such a fun pin!
I like the original look, but I did customize it with colored Perfect Play bands, and made my own Blasting Zone mod (flash looks bright red IRL).
#3570 58 days ago
Please help.
Simple explanation works best with me.
#3571 58 days ago
Quoted from MyParagon1979:
Please help.
I think I figured it out…. All making sense…
I need a Chris Hibler and a u24 6264.
Previously had reset issues,
Point well taken… the kahr was a bandaid.
All feedback appreciated!
#3572 57 days ago
Is this the correct 6264 RAM for U24 on the dot matrix controller board?
#3573 57 days ago
Try to reseat your connectors at the DMD and DMD controller board. If that does not work, try reseating the connectors between the MPU and the DMD controller.
#3574 57 days ago
Quoted from clempo:
Clempo,
Appreciate you taking the time and thought to help.
Already tried, figuring that was the easiest test.
Will try again later today, outta respect and hope from your feedback!
J
#3575 57 days ago
Clempo,
J
I keep repeating myself, but for me it was a revelation that the problem was the connector two boards away.
#3576 54 days ago
Are there any good videos on how to assemble the heads? I have the eyes in but they are quite tight, not sure how to get the eyelids on either
#3577 53 days ago
Quoted from allsportdvd:
A Rudy series is available, it's applicable for RS:
#3578 53 days ago
Okay heads assembled! Thanks for the video
Now next question, part number for the spring on the underside of the bulldozer blade?
03632150-0B2B-42F2-8485-4E137F4FF6A3 (resized).jpeg297FDEC4-ADBF-4CF6-852F-75799710CFE4 (resized).jpeg
#3579 53 days ago
10-408, extension spring
https://www.planetarypinball.com/mm5/merchant.mvc?Screen=PROD&Product_Code=SP-10-408&Category_Code=GS-1972
#3580 53 days ago
It's out of stock at PSPA. I think the standard ball gate extension spring will do the job. Cut it, and bend the end similar to original spring.
https://www.pinballspareparts.com.au/catalogsearch/result/?q=10-194
#3581 53 days ago
Looks like you might be missing these in the eyelid. NYLINER® 1/8 INCH SMALL 20-8790-1
Standard snap-in Nyliner® bearing 1/8 inch Inner Diameter
Reference:
Stern 545-5335-00
20-8790-9
#3582 53 days ago
Quoted from kdunbar:
Reference:
Stern 545-5335-00
20-8790-9
I have some of those. They push in from the outside of the heads
You’d think with a few hundred pictures I’d be covered but no. What goes in the circled part here?
#3583 53 days ago
You’d think with a few hundred pictures I’d be covered but no. What goes in the circled part here?[quoted image]
Apparently nothing.
#3584 52 days ago
Yup mine too
#3585 46 days ago
https://pinside.com/pinball/forum/topic/road-show-start-city-sign-bracket#post-7401920
Finished up making some straight brackets for the Start City Sign, let me know if you're interested. Have 8 extras.
#3586 42 days ago
Does anyone know the name or part number of this ramp switch bracket please? There's one on each ramp - both look to be identical.
Debating buying new replacements vs tumbling existing (which means putting a new plug on my tumbler...)
#3587 42 days ago
Quoted from monkeyboypaul:
Debating buying new replacements vs tumbling existing (which means putting a new plug on my tumbler...) [quoted image][quoted image]
Mantis makes these in stainless steel as well if you want to go that route...https://mantispinball.com/product/misc-ramp-switch-bracket/
#3588 42 days ago
Quoted from monkfe:
thanks! I absolutely would without thinking if the international postage didn’t hike the price up disproportionately for me…
#3589 42 days ago
It's 01-9476-2.
#3590 42 days ago
Marco sells them for $21 each.
https://www.marcospecialties.com/control/keywordsearch?SEARCH_STRING=01-9476-2
You can do a lot of tumbling for that price.
#3591 42 days ago
. I have some extras here. Bit I a long way to there.
#3592 41 days ago
5 minutes with a wire brush would clean those right up. I even put mine on a buffer wheel and polish them. Here is a cabinet bolt I just did.
#3593 39 days ago
I am due to start a full refurbishment of my Roadshow and am really trying to track down a set of Official Planetary Pinball Cabinet Decals. Does anyone know of any available anywhere or does anyone have a set they would be willing to sell. I have a set from elsewhere, but the colour match is no where near the originals.
Any help or advice in tracking down a set of Official PPS Roadshow Cabinet Decals would be greatly appreciated.
#3594 39 days ago
Quoted from Andypc:
Be careful.
Official/licensed/geniune with a hologram sticker on it means -> royalty to PPS, nothing more. Quality/color match is not guaranteed.
#3595 39 days ago
Does anyone know the item number for the spring that goes around the cam for the dozer blade beneath the playfield? Mine is missing and I can’t find it referenced in the manual.
#3596 39 days ago
Quoted from Andypc:
Consider Pinball Decals EU. I have a set of RS decals from them that I will be installing next weekend. I placed JM decals from their shop and they were excellent. Only took around 2.5 weeks to receive in the US after ordering. I'm sure you'll get yours faster. I'll post pics here after I place them.
#3597 39 days ago
Quoted from tjprice222:
#3600 31 days ago
I have a few strange issues to try and solve on my Roadshow. Would be grateful for any advice on what to check.
1. The volume doesn't actually change when I change the volume. On screen it shows the volume change when I press the buttons between 8 and 31, but the actual volume of the machine stays the same.
2. I am not getting the beep sound when I scroll through the menus. In game sound seems fine.
3. Red's eye are not moving. Eyelids are working fine.
4. Two of the pop bumper lights are really dim.
KAHR.US Circuits
$ 649.95
Pin Stadium Pinball Mods
Led
$ 29.99
Lee's Parts
Interactive
This page was printed from https://pinside.com/pinball/forum/topic/road-show-club-hard-hats-required-on-site/page/72 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
