(Topic ID: 83745)
ROAD SHOW CLUB (Hard hats required on site)
By webdiddy
7 years ago
  • 2,557 posts
  • 342 Pinsiders participating
  • Latest reply 17 hours ago by Stebel
  • Topic is favorited by 135 Pinsiders
RS22.JPG.pdf (PDF preview)
RS33.JPG.pdf (PDF preview)
There are 2557 posts in this topic. You are on page 51 of 52.
#2501 55 days ago
Added a few toys
What ya think?
#2502 54 days ago
I am trying to obtain a compression spring 10-424 for the eyelids and cantering flange, (either or both would be great). If any one can help it would be much appreciated. The only place who will post to Australia is the Pinball Centre and they want nearly $100 freight.
Many thanks.
#2503 54 days ago
Quoted from TOLLS:
Many thanks.
Just a tip I printed out earlier in this thread:
"When I renovated my heads I replaced all springs with new ones (having the correct part numbers) but the new springs were stiffer than the original ones and the eyes refused to work properly until I put back the old springs again. Maybe they could have worked if I changed the head coils to new (stronger?) ones too."
If you have the old springs it might be better to use them.
#2504 54 days ago
TOLLS hi. I think I have 1 new from funhouse. I’ll look tomorrow if I have it I’ll send you pics and let me know.
#2505 54 days ago
Paseb. Looks good. If I were you I’ll find a construction LEGO guy. The one that comes whit the yellow helmet and sit it in the bulldozer.
#2506 54 days ago
Quoted from Lhyrgoif:
One is not original. It is less stiff and the resistance seems to be not enough. I am assuming that is the reason the eyebrows broke. The eyebrows came repaired. The coil had a make shift coil stop and centering flange. I assume this was to try and fix the problem.
#2507 54 days ago
Quoted from Santis:
#2508 54 days ago
Quoted from Santis:
You wouldnt have any link by any chance?
#2509 54 days ago
Hey guys, anyone using pinstadium? Or comet spotlight? My center playfield is very dark and id like to adress that.
Id like to see your pictures
Thx
#2510 54 days ago
Quoted from Paseb:
Thx
Add an extra spotlight or two and aim them at the center? I've done the same on dark pins like TAF.
It's super easy, just connect them to a GI socket below the pf.
#2511 54 days ago
Quoted from Paseb:
Thx
My buddy just added some Pinstadiums and they look amazing. They are a tight fit on the left side, due to the ball rails, but definitely do able. I'll show some pics later, when we get the rest of the lighting completed. I don't want to misrepresent the Pinstadiums or shoot me a pm
#2512 54 days ago
Did shakers come standard in this machine or are they an add on?
#2513 53 days ago
Paseb hi. The eyes link? I may have 1. I’ll look tonight and let you know
#2514 53 days ago
Quoted from trk12fire:
Standard
Plz post pictures of the pinstadium. Which model did he choose?
Im on the fence, since its big money vs adding 30$ spot light
#2515 53 days ago
Quoted from Santis:
Thx, i think i will redo both set of eyes
#2516 53 days ago
Quoted from Paseb:
Thx
Just use 2smd warm white leds in the gi.
Lights it up nicely.
#2517 53 days ago
Quoted from Jjsmooth:
I have full led in my game, bottom center is just dark
#2518 53 days ago
pasant71 in mine I put the flexible leds from pinball life. Is lit
#2519 53 days ago
@pasab I meant.
#2520 53 days ago
Paseb ( stupid Autozone).
#2521 53 days ago
Quoted from Santis:
Pictures of your playfield now?
Any link of the parts youre talking?
#2522 53 days ago
@pased.
#2523 53 days ago
Quoted from TOLLS:
Many thanks.
Mr Pinball Australia has both
#2524 53 days ago
Quoted from Santis:
@pased.
i have these lights behind all the little green cards, but it doesnt light the center playfield, just the signs
#2525 52 days ago
Quoted from Ballypinball:Mr Pinball Australia has both
Different part number on the spring. Have found the flange.
Thanks for taking the time to assist.
#2526 52 days ago
Paseb. The center is always a little dark. I use those lights in all the gi’s.
#2527 51 days ago
Wouldn't these look great on Road Show....
https://pinside.com/pinball/market/shops/1282-rocket-city-pinball/04735-caution-posts-for-jurassic-park-road-show-amp-more
I just ordered 12 of them.
#2528 50 days ago
Hi Guys. Having an issue with my RS hoping someone can help.
The problem started with a snapped Dozer blade. I had a replacement blade handy, so I went to replacing it, deciding at the same time I'd take apart the actuator motor and clean it up and lube it. It desperately needed it, the grease inside looked like it was from the 1990s . Everything went together fine.
Now I've got a dozer blade that at first wouldn't go down because of a stretched spring (as best I can tell) and is also going up and down somewhat crooked. I've looked at the assembly and can't see anything binding - and when i run the test the motor functions perfectly - it just looks like for whatever reason something is creating enough resistance on the blade to make it "easier" to stretch the spring vs bring the blade down. Without a spring installed the blade seems to move up and down with a reasonable amount of tension. It doesn't "freefall" down but it also doesn't need a bunch of force. The blade also is not going all the way down to the playfield, although I can't remember if it did that originally.
Anyone run into this one? Is there something I'm missing regarding aligning the blade on the two axels on either side of Ted's head? Any other suggestions before I go really crazy and try to put a way stiffer spring on there?
#2529 50 days ago
Why would you need 12? According to the Road Show manual there are only 2 of those style posts in the game.
#2530 50 days ago
Just curious do any full restored RS come up for sale ? Use to have a beater and really enjoyed the game. Been searching for a while for a really nice one,clear coated playfield ect.... Thx
#2531 50 days ago
For the dozer blade, make sure that all of the cogs are in both gears and that they are lined up properly.
#2532 50 days ago
Quoted from hlaj78:
The motor is working perfectly, it's the connection between the yoke and the "cam" on the motor that seems to be flaky. I'll try a stiffer spring, just wondering if I'm missing something re: where the blade attaches to Ted's head? Should it fall freely or is there a bit of resistance there when the yoke isn't connected?
#2533 50 days ago
Quoted from Paseb:
Here is mine. Incandescent controlled lamps, 2 smd leds in gi. Nothing else.
Looks plenty bright to me.
#2534 50 days ago
Gameroom ready
#2535 49 days ago
Quoted from THJM:
A few spares and for someone else his game.
Maybe I add a post in a place where it looks good and does not interfear with gameplay.
#2536 47 days ago
Is the J120 & J121 reversed on the schematics? My friends game came with J120 on J121 and vise versa. Pictures I've seen on the internet show them reversed as well. Can someone show me a pic of working J120 and 121? The left side of his play field won't light. It's not a fuse, we replaced some connectors, cabinet wiring good. I'm wondering if Q12 could be an issue.
Schematics
J120-1 Brown, return, G.l. to playfield
J120-2 Orange, return, G.l. to playfield
J120-3 Yellow, return, G.l. to playfield
J120·4 Key
J120·5 Green, return, G.l. to playfield
J120-6 Violet, return, G.l. to playfield
J120-7 White-Brown, 6.8Vac, G.I. to playfield
J120·8 White-Orange, 6.8Vac, G.l. to playfield
J120·9 White-Yellow, 6.8Vac, G.l. to playfield
J120-10 White-Green, 6.8Vac, G.l. to playfield J120·11 White-Violet, 6.8Vac, G.l. to playfield
J121-1 Brown, return, G.l. to insert panel
J121-2 Orange, return, G.l. to insert panel
J121-3 Yellow, return, G.l. to insert panel
J121·4 Key
J121-5 N/C
J121~6 N/C
J121·7 White-Brown, 6.8Vac, G.l. to insert panel
J121-8 White-Orange, 6.8Vac, G.l. to insert panel
J121-9 White-Yellow, 6.8Vac, G.l. to insert panel
J121-10 N/C J121-11 N/C
#2537 47 days ago
My understanding is that J120 and J121 can be used interchangeably.
#2538 47 days ago
Quoted from THJM:
Yes, they are.
Check if the playfield light work if you change J120 to J121 and vice versa.
If it works, check the connections between J120 and J121.
#2539 47 days ago
Thanks guys, we tried swapping the connections with no change. We're going to add all new molex and repin J120 and see what happens.
#2540 43 days ago
Has anyone come up with a source for the ramp decals yet other than the one company in Germany?
#2541 43 days ago
Quoted from monkfe:
Not to my knowledge here locally in the US. I did however purchase the ones in Europe that your referring to. They actually are pretty decent. Put them on JodyG's new repro RS ramps. I'm pretty happy how they came out!
RS22.JPG.pdfRS33.JPG.pdf
#2542 42 days ago
Yeah not bad.....may be my only choice....
#2543 41 days ago
Hi all
I am making spinner decals for Bally/Williams stuff that have these holographic decals - many games from the 80's and 90's. In general they are $2.50 shipped in the US for a pair and $4.00 shipped international for a pair. Shipping stays the same if you buy more.
PM me if interested.
Dan
3 weeks later
#2544 17 days ago
My RS has comet leds in, but whoever did it made a few strange choices (I found some red and orange in GI so swapped them for the sunlights elsewhere).
I put the red under the Extra ball insert next to the lock insert.
The lock and bobs bunker inserts don't feel bright compared to the white and red inserts they're next to.
What colour and type of led would be better suited for those?i tried orange but it didn't look any better
#2545 11 days ago
Just brought mine home today!
#2546 11 days ago
Quoted from Steve_d71:
Really nice
Another one in canada
If you want to sell your topper one day, hook me up
#2547 9 days ago
Great topper! Welcome to the club
#2548 9 days ago
Is that topper really popular or something? Mine had one when I bought it, and honestly I really don't givashit that its there...
#2549 9 days ago
Quoted from TheOnlyest:
A pinsider made a limited quantity of it, that was years ago.
I will buy yours. If you want to sell.
#2550 8 days ago
**SOLD** Anyone want these? Bought them when I owned RS, never installed them. They are not NOS, but repros. Thick plastic! $10 shipped in the US.
