New! Dark mode!
(Topic ID: 83745)
ROAD SHOW CLUB (Hard hats required on site)
By webdiddy
6 years ago
  • 2,353 posts
  • 320 Pinsiders participating
  • Latest reply 6 days ago by TOLLS
  • Topic is favorited by 124 Pinsiders
There have been 610 images uploaded to this topic. (View topic image gallery).
There are 2353 posts in this topic. You are on page 47 of 48.
#2301 46 days ago
Quoted from DakotaMike:
Just joined the club. Got my RS setup for the first time today, but I'm having an issue with Ted's dozer. It randomly goes up and down during play, and will score points when it does this. It registers shots correctly, but sometime during play it will just start going up and down and scoring points, but it doesn't actually trigger day progression or anything.
Has this happened to anyone else? Could a problem with one of the eddy boards cause this type of behavior? Just trying to figure out where to start. Thanks in advance.
Quoted from gutz:
Going from memory - theres an eddy board on both sides of the dozer. The inside one is likely your issue, sounds like the game thinks there is a ball inside the dozer. Lift playfield and adjust the eddy sensor. If the led is on, the switch is closed. Back the pot off until the led goes out, and test with a ball above the playfield.
Quick Follow-up: Yep, it was the interior Eddy sensor between the blade and Ted's mouth. It was set too sensitive, so that even simply touching the screwdriver to the pot would trigger the LED. Backed it off a little and no more phantom dozer blade lifts / ted hits.
My only real issue now is that sometimes Red's mouth drops down instead of returning to the closed/up position. At some point I'll need to dig in and investigate that, but at least it doesn't affect gameplay at all like the dozer issue.
#2302 46 days ago
I had the mouth not closing. In my case it was simply adding some foam tape, maybe 3mm thick to the end of the 1/4 cog to stop it travelling too far. If you need a photo let me know.
#2303 46 days ago
Quoted from TOLLS:
Thanks, I might take you up on that.
#2304 45 days ago
That’s Red, the foam tape has compressed to the cog line indents. It stops it travelling too far, only a couple of mm. Been working for hundreds of plays, might actually replace it while I’m looking at it.
#2305 43 days ago
This could probably be posted as a separate thread for better exposure but as it's inside a Road Show I'll put it here anyway and hope for some input.
I started renovating my newly bought game today and noticed the coin door inside looking like this (with some old electrical tape removed from the loose cable ends)
According to the manual the slam tilt should be connected with the green-red (still connected) and white-brown (cut and dangling), so I just solder that one back to the slam tilt switch right ?
I'm also curious what could have been previously connected to the cut red-blue and red-green cables, any suggestions ? It can't be another coin chute and what the heck would you want to piggy-back on the slam-tilt switch for?
#2306 35 days ago
Question about Soren rom patch:
IPDB L6 Patch contains rom that seems like it's already the full game rom with a patch? The size is same as L6 game rom and SHA1 matches the patch readme file. Am I missing something or can I just burn this directly?
I did test to combine L6 game rom and L6 game rom patch with Lunar IPS, then apply the batch on the L6 game rom and resulting rom still had the same SHA1.
#2307 35 days ago
This is what Soren sent me directly....https://www.dropbox.com/s/ybnrk1rd3xq4p8k/Road%20Show%20mod%20ccd1.zip?dl=1
#2308 35 days ago
Quoted from monkfe:
So basically we have to get the image of the official unpatched L-6 ROM (from ipdb.org?) , apply this patch to it and then write it to a ROM chip, then install in game. Any step I missed?
I have no idea what programs to use to apply the patch so if someone could send me a link to an already patched/fixed L-6 bin ready for writing that would be great.
#2309 35 days ago
Quoted from Lhyrgoif:
It looks like the link provided is the pre-patched ROM. So, you just need a burner and an EPROM. Or, there are a handful of folks online that provide a burning service.
#2310 35 days ago
Quoted from Coyote:
Ah, the readme for that zip said "The patch is distributed in the two patch formats Xdelta3 and Lunar IPS. Use either one. Just one of them, which ever suites you best. The patch files only contain the new code." but the actual content seem to be a complete ROM binary and not only the patch as stated, fooled me.
#2311 34 days ago
Quoted from TOLLS:
Thanks for the tip, I put some foam on mine today, and it helped quite a bit. The mouth still catches closed once in a while, but it seemed to be a lot less frequent than before. I've noticed that the gears for red's mouth seem a lot stiffer and harder to move than Ted's. So maybe it's time for some new gears? Or maybe a new motor?
I don't have any problems with Ted's mouth, so I'm guessing that Red's gears should be easier to move like his?
#2312 34 days ago
Another quick question for the club:
When Ted talks on my game, his faceplate moves up and down a little bit. I thought this was normal behavior, but after watching some videos, I don't think this is supposed to happen. The movement of the faceplate doesn't actually bother me, as it kinda makes him more lifelike, but is it bad if the faceplate moves?
Has anyone heard of this happening before? I don't want the movement to cause any damage. It just moves a little bit, but as I've never taken the heads apart, I don't know what the internals look like. So I have no idea how, or what, would be causing the faceplate to move during Ted's speech.
Any ideas? Thanks!
#2313 34 days ago
Any ideas? Thanks!
Tighten the 2 screws that hold the faceplate to the frame, they have worked loose.
#2314 34 days ago
Any ideas? Thanks!
The face mounting screws are loose.
#2315 34 days ago
Quoted from dsuperbee:
Quoted from gutz:
Gotcha, I'll give that a try tomorrow. Thanks.
#2316 33 days ago
Quoted from monkfe:
Thanks, this verifies it!
So all the descriptions and old forum posts are a bit misleading here as they all tell that the ipdb patch is patch only but size and sha1 say otherwise. Then ipdb says there's no readme file, even tho there is, and the readme files tell to use xd3 or ips patch files but they're not there. So ipdb file should be named "patched", not "patch".
The file you linked generated same sha1 (1b413100005efd63cb0344ff921e5d544abed6e4) as the file inside ipdb RSHW_L6 patch.ROM and this is the sha1 mentioned in the readme too.
#2317 32 days ago
Good morning. Apologies if this question has been answered but I couldn't find it searching on Pinside. I'm just looking for an LED map for Road Show. Has anyone taken the time to do this? Helping me determine the correct insert colors/base type would be incredible. There are so many bulbs under here! Thank you.
#2318 32 days ago
Well I took matters into my own hands. The manual has the controlled/insert lamp locations and wedge/base type. They do not specify color so I think I got it sorted out but we will see later this week when the bulbs arrive.
#2319 22 days ago
I'm in the middle of renovating my newly bought RS and I've come to the part where I'm pondering over what to LED and what not. Usually I let GI and backbox stay incandescent and all the inserts get LED and it will probably be the same on this one. It's been a while since I played a RS though and I can't remember if this game have a lot of fading/dimming GI or not, as that might affect my decision to LED the GI too (I like bright games).
I know about the different OCD boards but those are not an alternative at the moment (I've already spent way to much on replacement parts for this game).
#2320 22 days ago
Recently finished my restoration. I used 4x4 smd towers all round on gi. There are lots of dark bits on this game without side facing illumination. I tried freakin everything including colours.
Colour inserts are worth the spend. The map surrounds I went green, I have seen blue also, personal preference.
Blue frosted bobs and radio blue radio. White frosted low profile 5x and radio riot left habitrail red extra ball.
I removed the start whatever VUK sign. Hate that damn thing. Gets hit anyway. Moved that sign globe to under VUK and put in colour changer. Photos in this thread not long ago.
Leds in back box brightens the colours. The bulb where the exhaust is colour changer. Just adds a bit of interest to a static scene.
Can’t remember the spot light globes, but damn bright.
Don’t be cheap on illumination. Best, most visible $ you spend IMHO. I bought from comet, cost a bit to ship to Australia but what are you gunna do.
#2321 22 days ago
I used tower flashers in all flasher locations, color matched inserts with cool white in clear and yellow inserts and warm in orange. I used green on the land locations and blue at the water. 2smd frosted cool white for all GI. I used all non-ghosting as well. I was pretty happy with it. I got all my LEDs from cointaker.
#2322 22 days ago
Intensive dimming at extra ball, at multiball restart, at super payday, just to name a few. Without GI OCD board, it's like a strobe light. The dimming goes down to very low level.
#2323 22 days ago
That's exactly opposite of what I would recommend.
#2324 21 days ago
Quoted from Jjsmooth:
A game dimming the GI but using LEDs (and no GIOCD board) looks like crap in my opinion so your preference doesn't feel like an option here. If the game didn't have dimming then sure, why not LED for GI.
I tried LEDs for GI in White water (a title with lots of dimming) and it looked horrible with weird strobing and whatnot.
#2325 21 days ago
It's easy to disable the GI dimming in settings if someone wants LEDs but can't be bothered doing it properly. No more flicker when GI dims, because it never will.
Either leave it incandescent OR use regular non-anti-ghosting LEDS with a GI OCD board. Anything in-between is a compromise. Same goes for inserts!
#2326 21 days ago
Does anybody have an idea how to mechanically dimm LEDs with some kind of foil or similar? I‘m using red and blue leds for the map border but they are so extremely bright that it’s really disturbing - but I like the blue and red border...
#2327 21 days ago
Quoted from ClarkKent:
Leave the machine on for several hours, the brightness will die down a bit. LED's tend to cool off a bit over time compared to when they are brand new.
#2328 21 days ago
Quoted from monkeyboypaul:
It's easy to disable the GI dimming in settings ...
Oh, didn't know that existed as an option in the settings. Thanks, I will try it out
#2329 21 days ago
Quoted from JodyG:
The LEDs are in there for the last 6 years, don’t think they will cool off..
#2330 21 days ago
Do you want to loose the dimming effect or not?
#2331 21 days ago
Quoted from Davi:
I like dimming so will probably go with incandescents to keep that. Still I'm a bit curious about testing with leds and dimming turned off just to check the difference (might sacrifice dimming for a brighter lit game, not sure so need to test it I guess).
#2332 19 days ago
My Roadshow doesn’t have a shaker motor but I do have one of the official Stern Shakers spare. Has anyone fit a different shaker to their Roadshow with success?
#2333 19 days ago
Quoted from allsportdvd:
Stern shaker won’t work, voltage isn’t correct. I bought the one from Marco, pricey, but it worked. I posted in this thread about it.
#2334 18 days ago
Any know of someone selling switch covers on the left wire ramp. I saw them on pin side awhile back. Thanks.
#2335 18 days ago
I tried switch covers on this game. No longer use them. Not really enough room to fit well in my experience. Save the $.
#2336 12 days ago
After 6 years owning this game I accomplished Evil Toll Roads the first time! This mission is so extremely hard because of the short time available...
By the way - I never ever hit the target at the left small flipper. I tried a lot but as far as I can tell it’s not possible to hit it. Is there any trick?
#2337 12 days ago
...that target is best hit during a mode, it always awards you something towards your goal in that mode...and of course to hit it you just let the ball roll down the flipper without flipping it after entering the bunker
#2338 12 days ago
Quoted from monkfe:
No, no, you confuse this the the magic target at the upper left flipper. I mean the target at the small flipper.
#2339 12 days ago
ah yes...wrong target.....had to go look for the target you were speaking of...yeah can't recall if I've ever actually attempted to hit it...
#2340 11 days ago
In my opinion it’s impossible to willingly hit this target.
#2341 10 days ago
When I removed my original left plastic ramp I noticed that the plastic was cracked from having the metal diverter arm slamming into it over a long time. I am mounting a brand new repro-ramp and this one have the same problem, the diverter arm reaches the plastic before the diverter plunger hits the coil stop and stops the motion. Obviously I want to keep the new ramp in a good condition, but I'm unsure of how.
What I already thought of:
* I measured all the different coil stop brands that I had in hope of finding one that protruded a little bit longer and thus would stop the diverter earlier, but all was same or shorter length so no go.
* I looked at the actual diverter assembly in hopes that I could move it slightly sideways below the play field but the metal "arm" part that goes up through the play field are already resting against the side of the PF hole and can't be moved further (also, if I were to file the hole bigger it wouldn't help as there is a metal ball guide just beside it in the way too).
* I was thinking about straightening the actual diverter arm a bit, but it seems I would have to make it almost straight to avoid hitting the plastic and then the diverter wouldn't divert the ball to the side properly in it's rested position.
* Moving the actual ramp sideways is obviously a no go as there are lots of screw holes and hex-posts that would not longer fit at all (and other assemblies around it are also in the way).
* Thought about gluing a washer or two on to the coil stop to make it stop the arm earlier, but I'm scared the washers would deform over time or even worse, the glue wouldn't handle the stress and the washers come loose inside the coil sleeve. In the end I discarded this idea too.
* The metal plunger that moves inside the coil looks fine, no "mushrooming" in the end, so I doubt that I could order a new one that would be slightly longer (to stop earlier).
Any suggestions on what to do? Could I do something to the spring that's connecting the diverter arm and the plunger?
In the worst case scenario I will have to put a small dampening foam piece on the ramp to try and lessen the impact force from the diverter arm but it feels like a technically bad and visually ugly solution.
#2342 10 days ago
I haven't looked at this diverter since I last had my machine apart, ...are you sure you have the correct coil stop?...Do you have any pics of the mech?
#2343 10 days ago
Quoted from monkfe:
The assembly
The stops I tried with. The one to the far left is the type that was there when I bought the game. All 3 three stop a tiny bit "too late".
Not possible to move assembly more to the left (to get more distance to the ramp edge being hit).
There are no old/unused holes around the assembly so it shouldn't have been moved by a previous owner.
From my tests it seem that if I could get the plunger to stop ~2 mm earlier then the diverter arm wouldn't hit the plastic.
#2344 10 days ago
The assembly
so you can't just loosen the set screws and rotate the arm back a little?...then reset the screws...that's how I've done most of those diverter adjustments...
#2345 10 days ago
Quoted from monkfe:
If by "set screw" you mean the tiny black hex screw then no I don't think that's possible. The tiny screw goes against a flat surface on the diverter rod, which means if I rotate the rod and fasten the screw it will go back to the old 90 degree angle again. Or am I thinking wrong?
#2346 10 days ago
sometimes there are "flats" on those kinds of shafts...but I would think this should be adjustable there...take it apart and see if there is a flat on it...and when you remove it and there are any burrs, take a fine file and take off the burr a bit to facilitate the set screw "grab"
#2347 10 days ago
Quoted from monkfe:
There is a flat surface on my diverter rod, 100% sure. I checked that yesterday. The set screw also has a flat surface and not a pointy one, so I don't see how rotating the rod and screwing the set screw back would change anything as it will go back to the old 90 degree fastening angle again.
If it was round and not flat then this would have been easy to adjust
#2348 10 days ago
Hmm...any chance that the
Hmmm I'll take a look at mine tomorrow and look at the clearance at the ramp to diverter too...
#2349 8 days ago
bjsilverballs. Thanks for the great ideas for painting the boom box.
I used some of your ideas, but added a few.
Possibly a little too much “bling”, but fun with my daughter to do something together that we could both work on.
0CCBD941-7422-4DE8-87B1-B4C7ED87184D (resized).jpegEC6141D0-4834-424D-9AB1-F2CC5EFF2CB0 (resized).jpeg
#2350 7 days ago
My new personal highscore 6,125,000,000 points!
$ 54.99
